  3. How to count the number of times an instance appears in...
  • Views 3205
How to count the number of times an instance appears in a layout
JoeyV
JoeyV over 1 year ago
I have a layout with 10s of 1000s of instances and I would like to write a script that reports, for each instance found in the layout, the number of times that instance appears. I have a script that will list the master cells (instances) found that are unique in the entire hierarchy.
procedure(TrHierTraversal(cellView cellList)
  foreach(master cellView~>instances~>master
    let((nextCellView)
      nextCellView=master
        cond(
          (!nextCellView nil)
          (member(nextCellView cellList) nil)
          (t cellList=TrHierTraversal(nextCellView cons(nextCellView cellList))
          ); t
          ); cond
      ); let
  ); foreach
  cellList; return list of all master cells in hierarchy
); procedure
expansion = TrHierTraversal(dbOpenCellViewByType("my_library" "my_top_level_cell" "layout") nil)
foreach(item epantion printf("%L\n" item ~>cellName))
Thanks for your kind attention!
