  3. how to use schProduceUniqueCVHier in Scheme
  • Subscribers 150
  • Views 6428
kkdesbois
kkdesbois over 1 year ago
I'd like to use schProduceUniqueCVHier in a Scheme script.
My first intention was to write something like that :
(defun mainFun (lib cell view)
(let ( (cv (dbOpenCellViewByType lib cell view))
        (viewList (myGetViewList)) ; myGetViewList is a skill function
        (paramTbl (makeTable "paramTbl")) )
  (defun visitCB (cell depth hierPath stopCv)
    ;;; append paramTbl with found parameters in cell
  (schProduceUniqueCVHier 'visitCB cv viewList  nil nil)
But I get the following error : *Error* eval: undefined function - visitCB
The only way I found to make it work is to define visitCB with defglobalfun but I lose the benefit of the shared variable paramTbl.
Is there a way to do without using a global function?
Laurent.
    Laurent,
    Two things. First of all, even if you use defglobalfun, the function is still defined within the lexical scope and so can access lexically scoped variables (i.e. paramTbl). This mild modification of your code (just to record something in the visitor function) works fine:
        (defglobalfun visitCB (cell depth hierPath stopCv)
          ;;; just doing a dummy update for now
          (setarray paramTbl cell t)
        paramTbl
    (setq tbl (mainFun "ether" "top" "schematic"))
    However, schProduceUnqueCVHier also accepts a function object as the first argument. Because of this, you can do:
        (schProduceUniqueCVHier visitCB cv viewList  nil nil)
        paramTbl
    No global functions were needed here.
  • kkdesbois
    kkdesbois over 1 year ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for the asnwers.
    1. My understanding of lexical scoping is still weak and I didn't realize that even the global function (defglobalfun) accesses the parameters defined  in the same scope
    2. I had tried the syntax without the quote in schProduceUniqueCVHier. When I use defun instead for defining the function and use the syntax with the function object in schProduceUniqueCVHier, I get the foolowing error :
    *** Error in routine schProduceUniqueCVHier:
    Message: *Error* schProduceUniqueCVHier: argument #1 should be a symbol (type template = "sdggllg") at line 55 of file ...
    - funobj@0x4dfa02f0
    Andrew Beckett over 1 year ago in reply to kkdesbois
    Ah, this was a more recent change. In IC23.1 ISR5 (released end of February 2024) the function was updated to allow a function object to be passed; before that it was a symbol only as you have discovered. I assume you must be using an older version...
  • kkdesbois
    Exact.
    I usually use the last IC version available (I've been well educated by Cadence AEs ;))
    But exceptionnally, I was using IC20.1 ISR34 for testing other features of my code. So my trials of schProduceUniqueCVHier were in this current session.
    Finally, I'm a bit lucky because the final user of the code may use 20.1 or 23.1. So I will use defglobalfun which seems  to work with all ic versions.
    Thanks again for the support.
