  3. Looking for SKILL or Bindkey to change wire width based...
  • Replies 7
  • Subscribers 152
  • Views 6305
Looking for SKILL or Bindkey to change wire width based on list of width while doing wire command
Finn Huckle
Finn Huckle over 1 year ago
Hi Cadence Forum,
I am using virtuoso and familiar with the command Ctrl+Shift+Mouse Scroll Up/Down to change the wire width by increment.
Is there a SKILL, Bindkey or GUI way so that the wire width will change based on a list of widths instead of an increment?
    Andrew Beckett over 1 year ago +1
    I tried writing something that did this, but not happy with it for two reasons: The scroll wheel is a bit sensitive to cycling through two many widths in one step I've not got the window refreshing…
  • henker
    henker over 1 year ago in reply to Andrew Beckett +1
    I had a small x11 utility, that moves the mouse a bit using XWarpPointer, that I called with system() in order to trigger the canvas refresh for a more exotic trials; Maybe the problem of yours here is…
    Andrew Beckett over 1 year ago in reply to henker +1
    henker said: On second thought, here it could prob. also work to assign the new width from a list and than call "weScaleMagnifierOrIncreaseWidth() weScaleMagnifierOrDecreaseWidth()", which should not touch…
    1. The scroll wheel is a bit sensitive to cycling through two many widths in one step
    2. I've not got the window refreshing properly and so I don't see the change until I release all the keys on the keyboard (maybe if I can fix that, then point 1 might not be a problem)
    I'll continue tinkering a bit more (likely to be next week though).
  • henker
    You may have a look at the article, although this does not change the size inside the enterfunction but afterwards:
    support.cadence.com/.../ArticleAttachmentPortal
    This also implements changing width by increment, but you'd have at least some code to start with, and modifying it to use a list instead is rather simple (my actual code is company property so I cannot share).
    • Vote Up -1 Vote Down
  • henker
    I had a small x11 utility, that moves the mouse a bit using XWarpPointer, that I called with system() in order to trigger the canvas refresh for a  more exotic trials; Maybe the problem of yours here is similar, at least it sounds familiar. Although this is a quite ugly way, it did what I wanted back then. 'xdotool mousemove' should probably do the same if available.
    On second thought, here it could prob. also work to assign the new width from a list and than call "weScaleMagnifierOrIncreaseWidth() weScaleMagnifierOrDecreaseWidth()", which should not touch the new width but do the missing refresh.
    I'd been trying various hiFlush/hiUpdate/hiSynchronize/hiRedraw approaches and nothing helped, and had just come to the same conclusion that calling the existing bindkey function to take advantage of that would be a good idea - when I saw your post. That also has the benefit of showing the width next to the wire being drawn.
    The code works quite well - comments in the code and example of how to register the list of widths at the top.
    /* CCFcycleWireWidths.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       May 08, 2025
    Modified
    By
    Uses SKILL++ lexical scoping to take advantage of local functions
    and private data, so keep the .ils suffix on this file.
    Example:
    CCFregisterWireWidths(list(0.14 0.2 0.3 0.5 0.7 0.9))
    hiSetBindKeys("Layout" list(
        list("Ctrl Shift<Btn4Down>" "" "CCFincreaseWireWidth()")
        list("Ctrl Shift<Btn5Down>" "" "CCFdecreaseWireWidth()")
    Note that this is a proof of concept. You could extend this to
    allow per-layer and per-technology widths (although figuring out
    the current layer in the middle of create wire might be hard).
    SCCS Info: @(#) CCFcycleWireWidths.ils 05/08/25.21:23:17 1.1
    let((wireWidths)
      *             CCFregisterWireWidths(listOfWidths)              *
      *      Global function to register a list of wire widths       *
      globalProc(CCFregisterWireWidths(listOfWidths)
        wireWidths=listOfWidths
      *                changeWireWidth(win increase)                 *
      *  Local (internal) function to change the wire width through  *
      *  the registered list, either increase (t) or decrease (nil)  *
      procedure(changeWireWidth(win increase)
        letseq((
          (cvId geGetEditCellView(win))
          (techId techGetTechFile(cvId))
          (wireForm leGetTechFormList(techId)->wireForm)
          (wireWidth wireForm->wireWidth->value)
          remainingWidths
          if(increase then
            remainingWidths=exists(width wireWidths width>wireWidth)
          else
            remainingWidths=exists(width reverse(wireWidths) width<wireWidth)
          when(remainingWidths
            wireForm->wireWidth->value=car(remainingWidths)
          ; force an update. By increasing then decreasing, it leaves
          ; it at the level set by the code above
      *  CCFincreaseWireWidth(@optional (win hiGetCurrentWindow()))  *
      *  Increase the wire width to the next in the list of widths   *
      globalProc(CCFincreaseWireWidth(@optional (win hiGetCurrentWindow()))
        if(hiGetCurrentCmd(win)=="Wire" then
          changeWireWidth(win t)
        else
      *  CCFdecreaseWireWidth(@optional (win hiGetCurrentWindow()))   *
      * Decrease the wire width to the previous in the list of widths *
      globalProc(CCFdecreaseWireWidth(@optional (win hiGetCurrentWindow()))
          changeWireWidth(win nil)
        else
  • Finn Huckle
    Finn Huckle over 1 year ago in reply to Andrew Beckett
    Hi Andrew Beckett ,
    Thank you for the response.
    The SKILL script you created is now working.
    But we encountered some minor hiccups:
    1. Code works for leHiCreateWire() but doesn't work on leHiCreateBus() is it possible to make it work for both?
    2. We set the max wire width as 4.5 (This is the max for the technology we are using) but SKILL script stops at 4.49 (see screenshot)
        Is it possible to fix it?
    Andrew Beckett over 1 year ago in reply to Finn Huckle
    I updated the code to address both of these. I plan to add support next week (when I have a moment) for per-layer width lists (since I think that would be useful too - just didn't have time to do that...)
    Author     A.D.Beckett
    Language   SKILL
    Date       May 08, 2025
    Modified   A.D.Beckett
    By         May 09, 2025
    Example:
    allow per-layer and per-technology widths.
    SCCS Info: @(#) CCFcycleWireWidths.ils 05/09/25.08:51:40 1.2
    let((wireWidths)
      procedure(changeWireWidth(win increase @optional (formName 'wireForm)
                  (widthField 'wireWidth))
        letseq((
          (wireForm get(leGetTechFormList(techId) formName))
          (wireWidth get(wireForm widthField)->value)
          (isString stringp(wireWidth))
          (wireWidthNum if(isString atof(wireWidth) wireWidth))
          remainingWidths
          if(increase then
            remainingWidths=exists(width wireWidths width>wireWidthNum)
          else
            remainingWidths=exists(width reverse(wireWidths) width<wireWidthNum)
            get(wireForm widthField)->value=
              if(isString lsprintf("%g" car(remainingWidths)) car(remainingWidths))
          ; it at the level set by the code above. Ordering is to ensure
          ; that if the min or max width then you don't end up one step
          ; before that limit
          if(increase then
          else
        let(((viewType deGetViewType(win)))
          case(hiGetCurrentCmd(win)
            ("Wire" changeWireWidth(win t))
            ("Bus"
              changeWireWidth(
                win t if(viewType=="maskLayout" 'busForm 'busBetterTierForm)
                'busWireWidth
            (t weScaleMagnifierOrIncreaseWidth())
            ("Wire" changeWireWidth(win nil))
            ("Bus"
              changeWireWidth(
                win nil if(viewType=="maskLayout" 'busForm 'busBetterTierForm)
                'busWireWidth
            (t weScaleMagnifierOrDecreaseWidth())
  • Finn Huckle
    Your new code works!
    Yeah, a per layer feature would be great.
    We are trying to use a grid/track workflow, and this type of SKILL made the implementation easier.
    Thanks always for the help.
