  3. Reading and printing log file created for a calibre process...
  • Views 5044
Reading and printing log file created for a calibre process using skill
CG20240827312
CG20240827312 over 1 year ago
Hi , iam running a calibredrv process using skill using ipcBeginProcess and storing the output in a log file. I want to print licences in use message if "licences occupied message displays in log file. Iam not able to read the log file fwith my following code as i guess the ipcProcess stops everything else the code tries to read the log file before it starts.
loc=[path]
changeWorkingDir(loc)
funstr="calibredrv [ctrl file] > out.log 2>&1 cellname.gds "
ipcBeginProcess(funstr)
unless(ipcBeginProcess(funstr)
file =infile("out.log")
while(gets(line file
if(rexMatchp("Warning :All Licence In Use" line) then
print("waiting for licence")
The calibre command works fine only issue is with reading the log file.
  • Aurel B
    Aurel B over 1 year ago +1
    Hi, You should try a different approach : You are starting a child process and reading its log direcly. At the time you read the log, your child process might not even be running yet. A solution could…
  • Aurel B
    A solution could be to parse the data as it comes from the process :
    procedure( custom_calibre_run ( run_dir ctrl_file "tt" )
      "Run `calibredrv` in RUN_DIR using CTRL_FILE"
      ;; You can add `ipcWait' here if you need to wait for child to terminate
      ipcBeginProcess(
        lsprintf( "cd %s && calibredrv %s cellname.gds 2>&1 " run_dir ctrl_file)
        lambda( ( _pid data )
          if( rexMatchp("Warning :All Licence In Use" data) then
            ;; Follow up code gan go here
    Please note that I haven't tested it.
    It might be safer to reconstruct the data to make sure you are reading proper lines.
    (Even though I am almost sure this should work out of the box)
    Cheers,
    Aurel
  • CG20240827312
    CG20240827312 10 months ago in reply to Aurel B
    Thanks Aurel, and apologies for replaying late.
    Works perfectly as needed.Blush
