  3. Compare 2 Time/Date values to determine which is older.
  • Views 1334
vtboy51
vtboy51 over 1 year ago
I am writing a piece of code to find schematics that are "older" than their respective layout views, is there a clean way in SKILL to compare 2 time/date strings to see which is older? Below is the format I will be comparing.
"Jul 11 21:21:16 2024"
  • AaronSymko
    AaronSymko over 1 year ago
    You can use the SKILL function "stringToTime" to convert a date/time string into an integer value representation (that can be used for comparison).
    For example:
    time1 = "Jul 11 21:21:16 2024"
    time2 = "Jul 11 21:21:16 2025"
    printf("%L is %s than %L\n" time1
      if(stringToTime(time1) < stringToTime(time2) "earlier" "later")
      time2)
    Andrew Beckett over 1 year ago in reply to AaronSymko
    Or even simpler, just use compareTime() on the two date strings you have.
  • vtboy51
    vtboy51 over 1 year ago in reply to Andrew Beckett
    Excellent, thanks.
