  3. Look for matches between 2 lists
  • Views 3138
vtboy51
vtboy51 over 1 year ago
I need to compare all items in list1 against the first element of the lists inside list2. (I need to output a report of cellOwners for all used cells in my design). When an exact match is found I'll print the cellName and ownerName and jump to the next item in list1 and repeat. Would I use 2 foreach loops?? What would be the most efficient method?
list1 = ("cellA" "cellB" "cellC" "cellD")
list2 = (("cellA" "John_Smith")
                     ("cellB" "Sally_Smith"))
  • AaronSymko
    AaronSymko over 1 year ago
    The canonical solution would use nested foreach loops; but a simpler, more efficient solution would be to use the "exists" function. Here are some examples:
    list1 = '("cellA" "cellB" "cellC" "cellD")
    list2 = '(("cellA" "John_Smith")
    ;; Example using nested foreach loops
    foreach(i list1
      foreach(j list2
        when(i == car(j)
          printf("cell %L found with owner %L\n" car(j) cadr(j))
    ;; Example using exists
    cellsAndOwners = exists(i list2 !null(member(car(i) list1)))
    foreach(i cellsAndOwners
      printf("cell %L found with owner %L\n" car(i) cadr(i))
    Andrew Beckett over 1 year ago in reply to AaronSymko
    Since the second list is an "assoc" structured list, you could just do:
    foreach(cell list1
      when(found=assoc(cell list2)
        printf("%s %s\n" cell cadr(found))
    If the list of cells and owners is long, you might  be better off putting it into a hash table first:
    cellsAndOwners=makeTable('ownerInfo nil)
    append(cellsAndOwners list2)
    foreach(cell list1
      when(owner=cellsAndOwners[cell]
        printf("%s %s\n" cell owner)
