  3. skill to copy maestro
  • Views 3143
dogman4
dogman4 over 1 year ago
Hi,friends
I want to copy maestro under the same cell named maestro2, what function is used.
I have tried the following code but it does not work.
srcList = gdmCreateSpec("Mylib_FVF" "FvfLdo_sim" "maestro" nil "CDBA")
dstList = gdmCreateSpec("Mylib_FVF" "FvfLdo_sim" "maestro_mc" nil "CDBA")
ccpCopyDesign(srcList dstList)
thx
    As both the warning message suggest when you run this "*WARNING* (ccpCopyDesign) Was expecting dest object of library type.", and the documentation states, the destination must be a library. This is not the appropriate API to use for copying a maestro view - it's for copying a design (after expansion). Instead you should use:
    src = gdmCreateSpec("Mylib_FVF" "FvfLdo_sim" "maestro" nil "CDBA")
    dst = gdmCreateSpec("Mylib_FVF" "FvfLdo_sim" "maestro_mc" nil "CDBA")
    srcList=gdmCreateSpecList()
    dstList=gdmCreateSpecList()
    gdmAddSpecToSpecList(src srcList)
    gdmAddSpecToSpecList(dst dstList)
    ; third argument of nil means don't overwrite
    ccpCopy(srcList dstList nil 'CCP_EXPAND_COMANAGED)
  • dogman4
    dogman4 over 1 year ago in reply to Andrew Beckett
    very thx,Andrew
    save a lot of time
