  3. How to move the pin label location in a schematic?
  • Views 3046
hongjr
hongjr over 1 year ago
I'm creating a script that adds instances to a schematic and automatically connects pins to those instances.
I can add pins well with the code I’ve written so far, but I want to change the placement of the pin labels.
When I use schCreatePin, the label justify is set to lowerCenter by default.
What I want to do is:
  1. Change the justify setting
  2. Move the label's XY coordinates
Could you give me some ideas?
Thank you very much for the great help.
procedure(addpin(pinlist)
let(()
y=0
pinMaster=dbOpenCellViewByType("basic" "iopin" "symbol" "" 'r)
foreach(pin reverse(pinlist)
pinlist=schCreatePin(newcv pinMaster pin "inputOutput" nil list(0 y) "R0" nil nil "signal")
y=y+0.125
  • RobMan
    RobMan over 1 year ago
    The label is a attached to (a child of) the pin shape object.
    pin~>children will reveal the child objects. It's unlikely anything but the label is attached to the pin but parse this list if you need to.
    Then you can change the location, orientation, justification etc.
    e.g. pin~>children~>justify="centerLeft"
