  3. Export to CSV efficiently? (code review)
  • Replies 7
  • Subscribers 152
  • Views 5125
UsableLoki
UsableLoki over 1 year ago
I wrote this function to export a list to a generated CSV file.  However the for loop takes hours to run (albeit I am exporting 100,000+ items, but still, the commands that generate these items change things in my project and those only take a few minutes).  I tried to create a 2nd order string buffer because I figured that fprintf to port may have been a bottleneck but this made it run even slower (ran all night and still wasn't done).  Can someone please offer any improvements to this?  I left the previously direct way of export via fprintf commands commented out.
procedure(writeListsToCSV(headerList ListOfLists fileNameSuffix location)
  let((buffer buffer2 comma currentDateTime DateTimeList TimeList year month day time fileName fileHandle lengthHeader)
  ; Get current date and time;;; getCurrentTime() ; => "Jan 26 18:15:18 1993"
    DateTimeList = parseString(getCurrentTime() )
    year = nth(3 DateTimeList)
    month = nth(0 DateTimeList)
    when(month == "Jan" month = "01")
    when(month == "Feb" month = "02")
    when(month == "Mar" month = "03")
    when(month == "Apr" month = "04")
    when(month == "May" month = "05")
    when(month == "Jun" month = "06")
    when(month == "Jul" month = "07")
    when(month == "Aug" month = "08")
    when(month == "Sep" month = "09")
    when(month == "Oct" month = "10")
    when(month == "Nov" month = "11")
    when(month == "Dec" month = "12")
    day = nth(1 DateTimeList)
    time = buildString( parseString( nth(2 DateTimeList) ":") "")
    currentDateTime = buildString( list(year month day time) "_")
    /* I couldn't get this to work, "/" as last character returns "\/" and the compiler hates "\"
    print(getchar(location strlen(location)))
    printf("\n")
    when(not(getchar(location strlen(location)) == "/")
    strcat(location "/")
    ; todo:need to incorporate isReadable(filePath) and getWorkingDir() for better flow
    fileName = strcat(location
                      currentDateTime
                      "_"
                      fileNameSuffix
                      ".csv")
    ; Write the headers
    buffer = strcat(buildString(headerList ",") "\n")
    printf("\nFor loop begins at: %s\n" getCurrentTime())
    lengthHeader = length(headerList) - 1
    ; Write the list values to the file
    for(j 0 length(ListOfLists)-1
        buffer2 = ""
        for(i 0 lengthHeader
            ;print(type(nth(i nth(j ListOfLists)))) ;;if missing values then check possible value type here
            ;printf("\n")
            if(i < lengthHeader then comma = "," else comma = "\n");buffer = strcat(buffer ",") )
            case(type(nth(i nth(j ListOfLists)))
                ('string
                    buffer2 = strcat(buffer2 nth(i nth(j ListOfLists)) comma)
                    ;fprintf(fileHandle nth(i nth(j ListOfLists)))
                ('flonum
                    buffer2 = strcat(buffer2 sprintf(nil "%f" nth(i nth(j ListOfLists))) comma)
                    ;fprintf(fileHandle sprintf(nil "%f" nth(i nth(j ListOfLists))))
                ('list
                    buffer2 = strcat(buffer2 sprintf(nil "%L" nth(i nth(j ListOfLists))) comma)
                    ;fprintf(fileHandle sprintf(nil "%L" nth(i nth(j ListOfLists))))
                ('float
                ('int
                    buffer2 = strcat(buffer2 sprintf(nil "%d" nth(i nth(j ListOfLists))) comma)
                    ;fprintf(fileHandle sprintf(nil "%d" nth(i nth(j ListOfLists))))
                ('fixnum
                ('t
                    buffer2 = strcat(buffer2 sprintf(nil "%s" nth(i nth(j ListOfLists))) comma)
                    ;fprintf(fileHandle sprintf(nil "%s" nth(i nth(j ListOfLists))))
            ;when(i < lengthHeader fprintf(fileHandle ",") )
        buffer = strcat(buffer buffer2)
        ;fprintf(fileHandle "\n")
    printf("\nFor loop ends at: %s\n" getCurrentTime())
    ; Open the file for writing
    fileHandle = outfile(fileName)
    ; Write
    fprintf(fileHandle buffer)
    ; Close the file
    close(fileHandle)
    printf("\nClosed file handle at: %s\n" getCurrentTime())
    printf("\nCSV GENERATED AT: %s\n" fileName)
  • henker
    henker over 1 year ago +2
    It's just a guess, but skill lists are single linked and accessing them by index takes linear time. So every time you do a "nth(i nth(j ListOfLists))" it takes j steps to reach the row and then i steps…
  • AaronSymko
    AaronSymko over 1 year ago +1
    You can use the SKILL profiler to pinpoint where your code has bottlenecks. For example, in the CIW, type the following: profile ( 'time) writeListsToCSV(/*enter args here*/) profileSummary ( ?file…
  • UsableLoki
    UsableLoki over 1 year ago in reply to AaronSymko +1
    I've already pointed it down to the forloop running for hours- the strcat or the fprintf are the only functions of substance within (unless sprintf() nth(nth)) or tpye() are culprits...). Will this profiler…
  • AaronSymko
    profile( 'time)
    profileSummary( ?file "/tmp/profile.results")
    Then, an inventory of runtimes will be listed in tabular format in /tmp/profile.results
  • UsableLoki
    I've already pointed it down to the forloop running for hours- the strcat or the fprintf are the only functions of substance within (unless sprintf() nth(nth)) or tpye() are culprits...).  Will this profiler be applicable if it is rooted within a cloak function?  My large processing script uses it to get anything done in a reasonable time frame
    trans = axlDBTransactionStart();
    axlDBCloak('NetProcessingThatMakesListsForCSV(specifiedLayer) '(disableDisplay shape branch));
    axlDBTransactionCommit(trans);
    Thanks for your response by the way!
  • UsableLoki
    Btw, how do you format type your code into here so it even picks up the IDE structure tags?
  • henker
    So every time you do a "nth(i nth(j ListOfLists))" it takes j steps to reach the row and then i steps to reach the column inside that row, doing thins inside two loops makes this operation O(N^2), which literally explodes when the lists get large. And you do this expensive thing all over the place.
    If you want to stay with the current structure, you could win alot by doing;
        buffer2 = ""
        row = nth(j ListOfLists)
          col = nth(i row)
          ; use col instead of nth(i nth(j ListOfLists))
    Though, it is inherently more efficient to use the language constructs to walk over lists, e.g
      foreach(row ListOfLists
        forech(col row
          ; do something with the col
    • Vote Up +2 Vote Down
    Andrew Beckett over 1 year ago in reply to UsableLoki
    Your post is really in the wrong forum - these APIs are from Allegro, so this should be in our PCB forums not in the Custom IC SKILL (which is for Virtuoso). The responses below are good anyway (particularly that from henker on the use of nth within a loop), but answering this specific question about how the profiler behaves with axlDBCloak (I have no idea what that does) is hard to answer for those of us without Allegro experience. I expect it will be OK, but I don't know for certain!
  • UsableLoki
    UsableLoki over 1 year ago in reply to Andrew Beckett
    Ah when I searched the community links I simply chose the one that said SKILL, had no idea the other options had sub-options in them.  Thanks for pointing this out!
  • UsableLoki
    UsableLoki over 1 year ago in reply to henker
    This did the trick, you helped immensely, thanks!!
