  3. DRC, LVS, parasitic extraction using SKILL
  • Replies 7
  • Views 7188
hoangtn3702
hoangtn3702 over 1 year ago
Hello everyone,
I am trying to use SKILL script to run DRC, LVS and parasitic extraction for a layout design. Do you have any suggestion on how to make this work?
Thank you very much!
    Which DRC, LVS and parasitic extraction tools are you using? What does your script look like at the moment, and what isn't working?
  • hoangtn3702
    hoangtn3702 over 1 year ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your reply.
    I am using Calibre to do DRC, LVS and parasitic extraction.
    First I am testing my commands in the CIW of the Cadence Virtuoso tool to see if it is working as expected or not. When I run the command system("calibre -drc lna_raw_drc_runset &") from the CIW, the output is "*Error* eval: undefined function - calibre". Then I tried with the command "system("which calibre")" from the CIW, the output is 1 and I don't receive any valid path (the output is supposed to be a valid path for calibre I guess).
    I check in the kit.tsmc65nm_gp.1.0c.csh file of the tsmc65nm process, there is a line with the command "source $CMC_HOME/scripts/mentor.calibre.2020.4_34.17.csh". I source the kit.tsmc65nm_gp.1.0c.csh file and then use "virtuoso &" everytime I start the tool but I am not sure why I cannot use the Calibre's command from the CIW.
    Is that the case that Calibre is only integrated into the tsmc65nm pdk itself instead of being installed into the Cadence Virtuoso tool (so I cannot use the Calibre command from the CIW)?
    Do you have any suggestion for my issue? My final plan is to automate the process of doing DRC, LVS and parasitic extraction using SKILL script instead of doing manually.
    Hoang
    Andrew Beckett over 1 year ago in reply to hoangtn3702
    There's a limit to how much advice I can give on Calibre since it's not a Cadence tool (it's from Siemens EDA, formerly Mentor), but a few notes:
    This can't be what you've done if it gives that error. You'd get that error if you entered:
    in the CIW, because the evaluator would think that you are trying to run a SKILL function called "calibre". If you called system, then any output that command produced would appear in the terminal in which you started virtuoso - so for me (because it's not in my path) I get (in the terminal):
    sh: calibre: command not found
    (not surprising, since I don't have access to Calibre).
    You'd get the path (or an error) in the terminal, and system would return the exit status in the CIW. Since the exit status is 0, then calibre is not in the path. I get 1 as well, and in the terminal:
    which: no calibre in (/export/home/apps/IC618_isr/bin:/export/home/apps/IC618_isr/tools/bin/64bit:/export/home/apps/IC618_isr/tools/bin:/export/home/apps/IC618_isr/tools/dfII/bin:/usr/local/bin:/bin:/usr/bin:.:/export/home/apps/SPECTRE231_isr/bin:/export/home/apps/PVS231_latest/bin:/export/home/myuser/lib:/usr/local/libexec/cssc:/export/home/apps/sbcl-1.1.16/bin:/usr/local/go/bin)
    Before running virtuoso, try "which calibre" in the terminal window to see if it's found.
    That script is something set up at your site - it's not provided by the foundry. So you should check with whoever developed it. Check too with the terminal test that I suggested above - and then try to figure out where Calibre is installed (maybe Calibre isn't installed in the right place or something is going wrong in this setup script - hard to know because it's nothing standard.
    No. It's just a matter of the UNIX path being set up properly.
  • hoangtn3702
    Thank you very much for your reply.
    Yes for this part I also get an error in the terminal as below:
    which: no calibre in (/CMC/tools/cadence/IC06.18.120_lnx86/bin:/CMC/tools/cadence/IC06.18.120_lnx86/tools/bin/64bit:/CMC/tools/cadence/IC06.18.120_lnx86/tools/bin:/CMC/tools/cadence/IC06.18.120_lnx86/share/oa/bin:/CMC/tools/synopsys/wv_vQ-2020.03/wv/Q-2020.03/bin:/CMC/tools/mentor/ixl_cal_2020.4_34.17/bin:/CMC/tools/cadence/QUANTUS20.12.000_lnx86/tools.lnx86/bin:/CMC/tools/cadence/QUANTUS20.12.000_lnx86/bin:/CMC/tools/cadence/SPECTRE20.10.155_lnx86/tools.lnx86/dfII/bin:/CMC/tools/cadence/SPECTRE20.10.155_lnx86/tools.lnx86/bin:/CMC/tools/cadence/SPECTRE20.10.155_lnx86/bin:/CMC/tools/cadence/EXT19.13.000_lnx86/bin:/CMC/tools/cadence/EXT19.13.000_lnx86/tools/bin:/CMC/kits/local/bin:/CMC/tools/cadence/IC06.18.120_lnx86/tools/dfII/local/bin:/CMC/tools/cadence/IC06.18.120_lnx86/tools/dfII/bin:/home/qmnguyen/python39/bin:/home/qmnguyen/.local/bin:/CMC/tools/synopsys/syn_vD-2010.03-SP4/bin:/CMC/tools/synopsys/syn_vD-2010.03-SP4/amd64/syn/bin:/CMC/tools/synopsys/syn_vD-2010.03-SP4:/CMC/tools/cadence/XCELIUMMAIN20.03.008_lnx86/tools.lnx86/bin:/CMC/tools/cadence/XCELIUMMAIN20.03.008_lnx86/tools/bin:/CMC/tools/cadence/XCELIUMMAIN20.03.008_lnx86/bin:/CMC/tools/cadence/MMSIM_07.20.109_lnx86/tools/dfII/bin:/CMC/tools/cadence/MMSIM_07.20.109_lnx86/tools/bin:/CMC/kits/local/bin:/CMC/tools/cadence/IC5141USR5_lnx86/tools/dfII/local/bin:/CMC/tools/cadence/IC5141USR5_lnx86/tools/dfII/bin:/CMC/tools/cadence/IC5141USR5_lnx86/tools/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/usr/bin:/local/bin:./)
    I also tried with "which calibre" in the terminal as you suggested and this output:
    calibre: Command not found.
    Yes for sure I will try to figure out if my Calibre is being set up properly. I think the problem might be due to this setup.
    Thank you so much for your suggestions!
    Have a great day!
  • hoangtn3702
    hoangtn3702 over 1 year ago in reply to hoangtn3702
    Hello Andrew,
    I think I already set the path properly as you suggested. Now when I run the command "which calibre" from the terminal (before running virtuoso), I got the output as below:
    /CMC/tools/mentor/aoi_cal_2020.4_34.17/bin/calibre
    However, when I run the command "calibre -drc -runset /home/qmnguyen/tsmc65nm/hoangtn/lna_raw/layout/lna_raw_drc_runset &" from the terminal, the output is as below and seems to be not responding for a long time. I think it is just printing out its environment, licensing, and usage information.
    Is that because I did something wrong? Do you have any suggestion on this?
    The content of my lna_raw_drc_runset (which I saved from the manual DRC procedure using Calibre) is as follows:
    *drcRulesFile: /CMC/kits/tsmc_65nm/CRN65GP/PDK/Calibre/drc/calibre.drc
    *drcRunDir: /home/qmnguyen/tsmc65nm/hoangtn/lna_raw/layout/lna_raw_drc
    *drcLayoutPaths: lna_raw.calibre.db
    *drcLayoutPrimary: lna_raw
    *drcLayoutLibrary: hoangtn
    *drcLayoutView: layout
    *drcLayoutGetFromViewer: 1
    *drcResultsFile: lna_raw.drc.results
    *drcSummaryFile: lna_raw.drc.summary
    *drcDFMDefaultsResultsFile: lna_raw.dfmDefaults.db
    *cmnSlaveHosts: {use {}} {hostName {}} {cpuCount {}} {a32a64 {}} {rsh {}} {maxMem {}} {workingDir {}} {layerDir {}} {mgcLibPath {}} {launchName {}}
    *cmnLSFSlaveTbl: {use 1} {totalCpus 1} {minCpus 1} {architecture {{}}} {minMemory {{}}} {resourceOptions {{}}} {submitOptions {{}}}
    *cmnGridSlaveTbl: {use 1} {totalCpus 1} {minCpus 1} {architecture {{}}} {minMemory {{}}} {resourceOptions {{}}} {submitOptions {{}}}
    *cmnFDILayoutLibrary: hoangtn
    *cmnFDILayoutView: layout
    *cmnFDIDEFLayoutPath: lna_raw.def
  • hoangtn3702
    [1] 90065
    [qmnguyen@cadclass3 ~/tsmc65nm]$ // Calibre v2020.4_34.17 Tue Dec 1 16:11:11 PST 2020
    // Calibre Utility Library v0-10_13-2017-1 Wed Jun 3 07:42:12 PDT 2020
    // Litho Libraries v2020.4_34.17 Tue Dec 1 16:11:11 PST 2020
    // Copyright Siemens 1996-2020
    // All Rights Reserved.
    // MemTotal: 495267868 kB
    // MemFree: 462286468 kB
    // MemAvailable: 483890660 kB
    WARNING: Please enable "throughput-performance" profile for best performance
    WARNING: Please increase max process limit (4096) to system limit (1933665)
    WARNING: Please increase descriptors limit for best performance (1024)
    // Processor AMD EPYC 7513 32-Core Processor [2511] (4th generation)
    // CPU Info: Cores = 64, SMT enabled with 64 additional virtual processors
    // Max file descriptors: 1024
    // 64 bit virtual addressing enabled
    // Running aoi_cal_2020.4_34.17/pkgs/icv/pvt/calibre -drc -runset /home/qmnguyen/tsmc65nm/hoangtn/lna_raw/layout/lna_raw_drc_runset
    // Process ID: 90065
    // Starting time: Sun Jul 20 22:34:04 2025
    --- CALIBRE_* ENVIRONMENT VARIABLES:
    CALIBRE_ATOMIC_LVHEAP=0
    CALIBRE_CMD_LINE='/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv/pvt/calibre -drc -runset /home/qmnguyen/tsmc65nm/hoangtn/lna_raw/layout/lna_raw_drc_runset'
    CALIBRE_HOME=/CMC/tools/mentor/aoi_cal_2020.4_34.17
    CALIBRE_INITIAL_CMD_LINE='/CMC/tools/mentor/aoi_cal_2020.4_34.17/bin/calibre -drc -runset /home/qmnguyen/tsmc65nm/hoangtn/lna_raw/layout/lna_raw_drc_runset'
    CALIBRE_READDB_LD_LIBRARY_PATH=/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv/julia/0.6/lib/julia:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv/julia/0.6/lib:/CMC/tools/mentor/aoi_cal_2020.4_34.17/shared/pkgs/icv/tools/calibre_client/lib/64:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/calibre_base/lib64:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv_lib/lib64:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv_qt5_comp/plugins:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv_oa/22.41p004/lib/linux_rhel68_gcc44x_64/opt:/CMC/tools/mentor/aoi_cal_2020.4_34.17/pkgs/icv_oa/22.41p004/lib/linux_rhel61_gcc44x_64/opt:/lib64:/usr/lib64:/lib:/usr/lib::/CMC/tools/cadence/MMSIM_07.20.109_lnx86/tools/lib:/CMC/tools/cadence/SPECTRE20.10.155_lnx86/tools.lnx86/lib
    CALIBRE_SKIP_OS_CHECKS=
    Usage: calibre [ -lvs { [ { -tl || -ts } <cnet_file_name> ]
    [ -nonames ]
    [ -dblayers "name1,..." ]
    [ -bpf [no-extents] ] [ -nl ] [ -cb ]
    } || { [ -hier [ { -automatch | -genhcells[=tvf_script] } ] ] } || { [ -flatten ] }
    [ -ixf ] [ -nxf ]
    [ [ -spice <spice_file_name> ] || [ -layout <spice_file_name> ] ]
    [ -hcell <cell_correspondence_file_name> ] [ -xcell <xcell_file_name> ]
    [ -siggen ]
    [ -nowait | -wait n | -lmretry <retry_args> ]
    [ -lmconfig <licensing_config_file_name> ]
    [ { { -turbo [ <number_of_processors> ] [ -turbo_all ] [ -lvs_supplement [ <number_of_processors> ] ] }
    } [ { -remote <host,host,...> || -remotefile <filename> || -remotecommand <filename> <count> } [ -remotedata [ { -recoveroff | -recoverremote } ] ] ] [ -hyper [ pathchk ] [ remote ] [ cmp ] ] ]
    [ -cmp_host <hostname> | -cmp_remotefile <filename> ]
    [ -waiver <waiver-setup-file-name> ]
    [ -E <svrf_output_from_tvf> ]
    [ -tvfarg <tvf_argument> ]
    [ -recon -si[=all|pg|io|db|tvf_script] ]
    <rule_file_name>
    calibre -recon -si[=all|pg|io|tvf_script]
    [ -turbo
    [ { [ <number_of_processors> ] || -turbo_all } ]
    -remotecommand <filename> <count> } ] ]
    {-svdb <svdb_dir>}
    calibre -version
    calibre { -lfd -hier [ { { -turbo [ <number_of_processors> ] [ -turbo_all ] }
    || { -turbo_litho [ <number_of_processors> ] }
    || { -turbo [ <number_of_processors> ] [ -turbo_all ] -turbo_litho [ <number_of_processors> ] }
    } [ -remote <host,host,...> || -remotefile <filename> || -remotecommand <filename> <count> ] [ -hyper ] ]
    <rule_file_name> [ -nowait | -wait n | -lmretry <retry_args> ] [ -lmconfig <licensing_config_file_name> ]
    calibre -3dstack { [-turbo [ <number_of_processors> ] ] [-system <GDS | OASIS>] [-create_assembly <assembly-name] [-use_assembly <assembly-file-path>]
    || -cs [count] } [-run_dir <directory-name>] <rule_file_name>
    As I said earlier, Calibre is not a Cadence tool, so I can't really advise on how to use it (I don't have access to it). You should ask this question to Siemens EDA (maybe via their support, or via a forum on their web site).
