  3. Skill code for saving the content of a notes block in a...
  • Views 2979
Skill code for saving the content of a notes block in a schematic to a file?
StephanWeber
StephanWeber over 1 year ago
I tried Grok AI to make some skill code for this task, but it failed.
I have some note blocks in my schematic (just pure descriptions), and I want to pick the one with starting with string "Key" into a text file.
However, the skill code fails to get even any notes block.
I am using ic 23.10.130.
The code to find notes (and more, just for debugging) is this:
; Check available collections
      let( (notes labels annotations figs text schText textDisplay shapes dbObjects)
        notes = cv~>notes || nil
        labels = cv~>labels || nil
        annotations = cv~>annotations || nil
        figs = cv~>figs || nil
        text = cv~>text || nil
        schText = cv~>schText || nil
        textDisplay = cv~>textDisplay || nil
        shapes = cv~>shapes || nil
        dbObjects = cv~>dbObjects || nil
        printf("Total notes in schematic: %d\n" length(notes))
        printf("Total labels in schematic: %d\n" length(labels))
        printf("Total annotations in schematic: %d\n" length(annotations))
        printf("Total figures in schematic: %d\n" length(figs))
        printf("Total text objects in schematic: %d\n" length(text))
        printf("Total schText objects in schematic: %d\n" length(schText))
        printf("Total textDisplay objects in schematic: %d\n" length(textDisplay))
        printf("Total shapes in schematic: %d\n" length(shapes))
        printf("Total dbObjects in schematic: %d\n" length(dbObjects))
But in CIW I get number of notes is zero.
So I think the key issue is that finding the notes should be done differently.
Inital code was this:
; Open the cell view
      cv = dbOpenCellViewByType(libName cellName viewName viewType "r")
      if(cv then
        printf("Schematic %s/%s/%s successfully opened.\n" libName cellName viewName)
      else
        error("Cannot open cell view %s/%s/%s" libName cellName viewName)
      ; Check for notes and labels
      let( (notes labels)
        notes = cv~>notes
BTW, my intention is to collect all key specifications in our IP blocks for documentation purposes. So the next step would be to get a top-cell and dive down in hierarchy.
Bye Stephan
    Andrew Beckett over 1 year ago +1
    Stephan, The dangers of using LLMs to write code... this has so many issues that you'll spend longer fixing it than writing from scratch. procedure(CCFwriteNotes(fileName @key (cv geGetEditCellView…
    Stephan,
    procedure(CCFwriteNotes(fileName @key (cv geGetEditCellView()) pattern)
      let(((pat pattern && pcreCompile(pattern)) port)
        port=outfile(fileName)
        unless(port
          error("Could not write file %L\n" fileName)
        foreach(shape cv~>shapes
          when(shape~>objType=="label" && shape~>layerName=="text"
            when(!pat || pcreExecute(pat shape~>theLabel)
              fprintf(port "%s\n" shape~>theLabel)
        close(port)
    Then you can use CCFwriteNotes("./notes.txt" ?pattern "^Key") ; if you specify a pattern, it's the regular expression to match the text. Without ?pattern it writes all note text.
  • StephanWeber
    StephanWeber over 1 year ago in reply to Andrew Beckett
    Works like a charm!! Extended it (with AI) to check the whole hierarchy and for multiple keywords.
    It can help me and all analog designers a lot. The only great improvement would be the ability to have nicer tables instead of only pure text note blocks. This is because often we need tables e.g. to define a trimming table, the DFT logic or the operating modes of an IP.
    If I want to re-use an analog circuit IP, I inspect always the schematic, and having hints and knowing the key parameters, such as gain, Idd, Vdd range, etc. is super-helpful. But we need this also in our general IP documentation, like in a Word document, for different review presentations, etc. For me the most native starting point is always "Cadence". Just because at the end, what is in a Word doc or ppt can be easily outdated, e.g. because I extended the trim bus by one bit or someone decides the default gain is 0.5V/A not 0.533V/A, etc.
    Bye Stephan
