  3. Skill code to automatically add cdsTerm("") in schematicSymbol...
  • Views 2800
Skill code to automatically add cdsTerm("") in schematicSymbol view
hongjr
hongjr over 1 year ago
I’m working on a Skill code that automatically appends cdsTerm("pin_name") in the schematicSymbol view.
I added the path to my code file in the .cdsinit, and the cdsTerm generation works correctly.
However, in all schematics, the terminals of instances are now labeled as nil, and the DC annotate voltage also shows nil.
When I comment out the code file in .cdsinit, the issue disappears.
What could be causing this problem? I’d appreciate any help or guidance.
procedure(cdsTerm()
let(()
cv = geGetEditCellView(hiCurrentWindow())
pin_name = cv~>terminals~>name
pin_xy = cv~>terminals~>pins~>figs~>children~>xy
pin_orient = cv~>terminals~>pins~>figs~>children~>orient
foreach((label_name label_xy label_orient) pin_name pin_xy pin_orient
label_x = car(car(car(car(label_xy))))
label_y = cadr(car(car(car(label_xy))))
label_or = car(car(car(label_orient)))
label = strcat("cdsTerm(\""  label_name "\")")
label_id = schCreateSymbolLabel(cv label_x:label_y+0.05 "analog pin annotate" label "centerCenter" label_or "stick" 0.0625 "ILLabel")
);foreach
);let
);procedure
    Your function is called cdsTerm - so what's happening is that you've redefined the function (it's normally a macro). That means that when the label is displayed, it calls your function but will silently catch the errors in it so you wouldn't see that.
    Why did you call it cdsTerm? Seems an odd choice... (just call the function HongjrAddCdsTerm or something like that).
  • Aurel B
    Aurel B over 1 year ago
    Also, to improve clarity, you might only browse the terminals and fetch the values you need instead of browsing 3 parallel lists.
    procedure( HongjrAddCdsTerm()
      foreach( terminal geGetEditCellView()->terminals
        let( ( text label label_x label_y )
          text    = strcat( "cdsTerm(\""  terminal->name "\")")
          label   = car( car( car( terminal->pins)->figs)->children)
          label_x = xCoord( label->xy)
          label_y = yCoord( label->xy)
          schCreateSymbolLabel( cv label_x:label_y+0.05 "analog pin annotate" text "centerCenter" label->orient "stick" 0.0625 "ILLabel")
  • hongjr
    hongjr over 1 year ago in reply to Aurel B
    I gave the function a short and intuitive name, but it ended up causing issues. After renaming the function, I confirmed that it works correctly.
    Thank you, Andrew.
    And thank you, Aurel B, for simplifying the code
