  3. Syntax help with hiCreateMLTextField
  • Views 3627
psill00
psill00 over 1 year ago
What is the syntax or what font can I use with hiCreateMLTextField?
How do I set the value in the cdsint
Is there another way to have the print larger in the field?
Paul
  • Aurel B
    Aurel B over 1 year ago
    Hi Paul,
    Unfortunately the ?font argument exists but I've never seen it supported anywhere.
    If you do not intend to use a different font for inputs but only to display nice things, then you have more possibilities.
    Here is an example of HTML field that will display what you typed with bold colored sans-serif face:
    (hiDisplayForm
      (hiCreateLayoutForm (gensym 'custom_form) "Custom Form"
        (hiCreateFormLayout 'main_layout ?items (list
            (hiCreateMLTextField
              ?name 'text_field
              ?changeCB
              (lambda (_field form)
                ;; Update HTML field using typed value
                (setf form->html_field->value
                  (lsprintf "<font face='sans serif' size='+2' color='firebrick' ><b>%s</b></font>" form->text_field->value)
                t)
            (hiCreateHypertextField
              ?name 'html_field
    Hope this helps,
    Aurel
  • psill00
    psill00 over 1 year ago in reply to Aurel B
    Big thanks for reply
    The script has the font variability I want but it does not or I have not found how to get it to support return line.
    The MLtext works; I just want like it to be easier to read.
    Paul
  • Aurel B
    Aurel B over 1 year ago in reply to psill00
    This is an HyperText field, so the syntax is now HTML.
    Newlines are not supported as you expect but you can use HTML tags to get return lines :
    You can for instance use <p>, <br/> or <pcre> for nice formatting of text and code.
    Here is an updated version of the previous example where input newlines are replaced by `<br/>` tags :
    (hiDisplayForm
              ?name 'text_field
              ?changeCB
                    (buildString (parseString (hiEscapeHTMLTags form->text_field->value) "\n" t) "<br/>")
                t))
              ?name 'html_field
