  3. What's wrong?
  • Views 1283
What's wrong?
Martinsh
Martinsh over 1 year ago
I've created a form with a Library combo field and a layer field. The layers in the layer field is decided by the value of the Library combo field. The code is as following. But there may have some problem. When I close and run it again, Virsuoto will crack. Please help.
procedure(test()
hiCreateLayoutForm(
'formTest
"test"
hiCreateFormLayout(
'layoutMain
?items list(
ddHiCreateLibraryComboField(?name 'lib ?prompt "Library" ?callback lambda((field form)
form->layer->techFile = techGetTechFile(ddGetObj(field->value))
leCreateLayerField('layer ?techFile nil ?layerFunction "metal")
?callback ""
hiDisplayForm('formTest)
  • mbracht
    mbracht over 1 year ago
    I can confirm this behavior - even though I need to run test() four or five times to make it crash.
    Can you open a customer support case on ask.cadence.com please.
    Max
