  3. enterpath preview path
  • Subscribers 152
  • Views 2871
Albertyu
Albertyu over 1 year ago
hi all!
when i use enterpath function, preview is black with boundary, if there is a way to preview path in the layout window when i create.
  • henker
    henker over 1 year ago
    It's not really clear what you are actually asking, though my guess is, you want the halo / drag image / dynamic highlighting, that is shown on the builtin commands.
    You can enable this with geSetEnterFunctionSelectionMode called in in initProc of the enter function, as shown e.g.in the example from support.cadence.com/.../ArticleAttachmentPortal
    The example uses enterPoints, but it is same with the other enter* functions, For more info, you can also refer to the manual with the keyword above.
