  3. Skill Pcell Post Trigger with doneProc
  • Subscribers 152
  • Views 3431
NC202503102342
NC202503102342 over 1 year ago
I read the post Skill Pcell Post Trigger Function - Custom IC SKILL - Cadence Technology Forums - Cadence Community but I couldn't find a lot of documentation on how to use doneProc.
I'm trying to access the bBox coordinates of the PCell and show the lower left point as a CDF parameter. My first approach was to use the following code
In the PCell code, I added the lines
cdfCreateParam( cdfId
?name "llCoord"
?type   ""float
?prompt  "PCell Lower left corner"
?editable   "nil"
?callback  "showLLCoord()"
cdfId->doneProc = "showLLCoord"
later, I have
procedure( showLLCoord()
let( ( bBox )
bBox = inst~>bBox
cdfgDat->llCoord~>value = listToVector( car( bBox ) )[0]
) ; let
) ; procedure
But it didn't work. How could it be done?
Thanks very much in advance.
  • NC202503102342
    correction:
    cdfgData->llCoord~>value = listToVector( car( bBox ) )[0]
  • henker
    henker over 1 year ago
    Without trying, I think you missed the following part of the citation:
    CDF doneProc - it gets passed the instanceId that was changed
    Your doneProc has no argument that would take the passed instanceId, though later you are trying to access the (then global) variable inst, which however will be prob. not defined. It might help to use:
    procedure( showLLCoord(inst)
    There are also mental shortcuts to access edges/corners of bBoxes, like leftEdge, rightEdge, lowerLeft, upperLeft, etc. that do what they are called, also see:
    support.cadence.com/.../techpubDocViewerPage
    So you do not need to twiddle the bBox with vectors.
