  3. How to use "schGlueLabel()" fucntion?
  • Views 1294
HJC
HJC over 1 year ago
Hello. How to use "schGlueLabel()" function?
I have run the "schGlueLabel()" function. but, it doesn't not work.
input : schGlueLabel(label figure)"
result : *** Error in routine schGlueLabel:
Message: *Error* schGlueLabel: argument #1 should be a database object (type template = "dd") at line 363 of file "*ciwInPort*" - (db:0x2f6ca3ea)
Entering new debug toplevel due to error:
[saved value]
1. Input : label ~>??
Result  : ((db:0x2f6ca3ea cellView db:0x2f6cad1a objType "label"
prop nil bBox
((2.9625 -0.76875)
(3.1625 -0.70625)
) children
nil groupMembers nil isAnyInst nil
isShape t matchPoints nil net
db:0x2f6ca42a parent db:0x2f6ca39e pin nil
purpose "label" textDisplays nil assocTextDisplays
nil markers nil figGroup nil
isUnshielded nil shieldedNet1 nil shieldedNet2
nil layerName "wire" layerNum 228
lpp
("wire" "label") connRoutes nil routeStatus
"normal" font "stick" height 0.0625
isDrafted t isOverbar nil isVisible
t justify "lowerCenter" labelType "normalLabel"
orient "R0" theLabel "net1" xy
(3.0625 -0.76875) hasTextDisplay nil
2. Input : figure~>??
Result : ((db:0x2f6ca3ed cellView db:0x2f6cad1a objType "line"
prop nil bBox
((2.6875 -2.4375)
(3.25 -2.4375)
) children
(db:0x2f6ca3ef) groupMembers nil isAnyInst nil
db:0x2f6ca42a parent nil pin nil
purpose "drawing" textDisplays nil assocTextDisplays
lpp
("wire" "drawing") connRoutes nil routeStatus
"normal" nPoints 2 points
((2.6875 -2.4375)
(3.25 -2.4375)
    Both label and figure are lists in your case. Assuming they are lists of a single database objects each (looks like it), you'd just do:
    schGlueLabel(car(label) car(figure))
