  3. change help file
  • Views 3007
change help file
Albertyu
Albertyu over 1 year ago
hi all!
i want callback my own help file in appform when i click help button, how can i achieve it. if you can reply with completed code that will be greatful !
thanks for reply
  • Aurel B
    Aurel B over 1 year ago
    I made you a custom snippet that shows most capabilities to display help in a GUI.
    This is SKILL++, if you don't understand everything that is going on, feel free to ask questions.
    I can also make an equivalent default SKILL snippet if you need:
    (inScheme
    (let ()
      (defglobalfun example_gui ()
        "Display an 'Example GUI'."
        (let ( ( form (create_form) )
          ;; Set form help callback
          (setf form->hiFormSym->hiHelpAction 'example_gui_help)
          ;; Display form under the mouse
          (hiDisplayForm form -1:-1)
      (defun create_form ()
        "Create the form and return it."
        (hiCreateLayoutForm (gensym 'example_form) "Example GUI"
          (hiCreateFormLayout 'main_layout ?items (list
              (hiCreateLabel ?name 'label ?labelText "<font size='+2' color='red'>Dummy Text...</font>")
              ;; Add a field wich displays a tooltip when hovered
              (let ( ( field (hiCreateStringField
                               ?name     'input
                               ?prompt   "Input"
                               ?defValue "This field displays a tooltip when hovered."
                ;; Tooltip is set here, it can be HTML
                (setf field->hiToolTip "<font size='+2'> <b>This is bold!</b><br/> <font color='red'>This is red!</font> </font> <br/>
    This text is a bit smaller...")
                field
              ));main_layout
      (defglobalfun example_gui_help ( @optional _obj_type _obj_name _obj_detail _more_detail @rest _ )
        "Custom help callback."
        (hiDisplayAppDBox
          ?name         (gensym 'example_form_help_dbox)
          ?dboxBanner   "Example GUI Help"
          ?dboxText     "Example GUI help goes here..."
          ?dialogType   (symeval 'hicInformationDialog)
          ?buttonLayout 'Close
      ));SKILL++ closure
    (example_gui)
    Cheers,
    Aurel
  • Albertyu
    Albertyu over 1 year ago in reply to Aurel B
    thanks your reply, appreciate.
