  3. Skill code for aligning any shape or instance at the midpoint...
  • Views 5300
Skill code for aligning any shape or instance at the midpoint of the ruler.
yogeshjaiswalCAD
yogeshjaiswalCAD over 1 year ago
Greetings Team,
Thanks for always being there for help. I need help with the skill code for aligning any shape or instance at the midpoint of the ruler in Virtuoso Layout Editor.
I have shared the concept reference.
; that depend on the exact view and object you're working with.
; 1. Get the selected object's bounding box
object_bBox = selected_object~>bBox
; 2. Calculate the object's center
object_mid_x = (car(object_bBox) + cadr(object_bBox)) / 2
object_mid_y = (cadr(object_bBox) + caddr(object_bBox)) / 2
object_mid_point = list(object_mid_x object_mid_y)
; 3. Define the target ruler midpoint (this part is highly dependent on your setup)
; For example, if you want to center it in the current view's X-dimension
cv = geGetEditCellView()
view_bBox = cv~>bBox
ruler_mid_point_x = (car(view_bBox) + cadr(view_bBox)) / 2
ruler_mid_point_y = (cadr(view_bBox) + caddr(view_bBox)) / 2 ; Or a specific ruler Y
; 4. Calculate the displacement needed to move the object's center to the ruler's midpoint
dx = ruler_mid_point_x - object_mid_point~>x
dy = ruler_mid_point_y - object_mid_point~>y
; 5. Move the object using a movement function (replace with actual function like leMoveFig)
; You'll need to select the object and then call a function to move it by (dx, dy)
; Example: leMoveFig(list(selected_object) list(dx dy) nil) ; Incorrect syntax for illustration
Please share with me any skill code for aligning any shape/instance at the midpoint of the ruler.
I will be grateful for your help. Please help in!
With warm regards,
Yogesh Jaiswal
    Andrew Beckett over 1 year ago in reply to Aurel B +2
    I just wrote a slightly different implementation because the requirements were slightly ambiguous. In my case if more than one object was selected, if moves the centre of the entire set (other than the…
  • Aurel B
    Aurel B over 1 year ago in reply to Andrew Beckett +1
    To be honest, I also had a more complicated solution but the forum did not let me post until I removed the `;unless ;Foreach obj` comment on the fourth line starting from the end... (No idea why but…
    Andrew Beckett over 1 year ago in reply to Aurel B +1
    Aurel B said: (No idea why but it seems ";Foreach" in lowercase is not allowed on the forum...) There are a few little oddities like this. There's one where the function that begins with sub and ends…
  • Aurel B
    This should do what you described:
    (defun cst_align_to_ruler
           ( @key  ( objects (geGetSelectedSet) )
             @rest _
      "Align all OBJECTS on ruler center.
    Exactly one ruler has to be selected"
      ;; Fetch ruler
      (letseq ( ( rulers (setof obj objects (equal "ruler" obj->objType)) )
                ( ruler  (or (car rulers) (error "No ruler is selected")) )
        (assert (not (cdr rulers))       "More than one ruler is selected")
        (assert (equal 2 ruler->nPoints) "Ruler has more than two points" )
        (destructuringBind ( ruler_x ruler_y ) (centerBox ruler->points)
          ;; Browse all objects except rulers (other object types could be filtered here...)
          (foreach obj objects
            (unless (member obj->objType '( "ruler" ))
              (destructuringBind ( obj_x obj_y ) (centerBox obj->bBox)
                (dbMoveFig obj obj->cellView (list ruler_x-obj_x:ruler_y-obj_y "R0" 1))
                );dbind
              ));unless ;foreach obj
          );dbind
        ));letseq ;fun
    I just wrote a slightly different implementation because the requirements were slightly ambiguous. In my case if more than one object was selected, if moves the centre of the entire set (other than the ruler) to the center of the ruler. I didn't bother checking that the ruler had only two points - that could easily be added.
    I also do a bit of messing around because if you're moving more than one object, you shouldn't move child objects which are attached to a parent that is also being moved (otherwise it moves twice).
    Anyway, with this and Aurel's code, you have a couple of alternatives to choose from (his is shorter because it doesn't worry about child objects or finding a common centre).
    procedure(CCFalignToRulerCenter(@optional (objects geGetSelSet()))
      let((rulers nonRulers rulerCenter objCenter transform
            (objTable (makeTable 'objects nil)))
        ; First pass through objects to find rulers and record
        ; potential objects to move
        foreach(obj objects
          if(obj~>objType=="ruler" then
            rulers=cons(obj rulers)
          else
            objTable[obj]=t
        when(!rulers || cdr(rulers)
          error("Must have exactly one ruler in the selected set")
        ; Filter the remaining objects to omit those where the parent
        ; (i.e. the object attached to) is also in the set
        foreach(obj objTable
          unless(objTable[obj~>parent]
            nonRulers=cons(obj nonRulers)
        unless(nonRulers
          error("Must have at least one object selected to move")
        ; Find the center of the ruler and all the other objects
        rulerCenter=centerBox(car(rulers)~>bBox)
        destructuringBind(((ollx olly) (ourx oury)) car(nonRulers)~>bBox
          foreach(obj cdr(nonRulers)
            destructuringBind(((llx lly) (urx ury)) obj~>bBox
              ollx=min(ollx llx)
              olly=min(olly lly)
              ourx=max(ourx urx)
              oury=max(oury ury)
          objCenter=centerBox(list(ollx:olly ourx:oury))
        ; Calculate transform and move all the objects
        transform=list(mapcar('difference rulerCenter objCenter) "R0" 1)
        foreach(obj nonRulers
          dbMoveFig(obj obj~>cellView transform)
        t
    • Vote Up +2 Vote Down
  • Aurel B
    It does not cover the children issues, but it checks the ruler orientation to align vertically or horizontally.
             @rest _
    Exactly one ruler has to be selected.
    If ruler is vertical, objects are aligned on its y coordinate.
    Otherwise, objects aare aligned to its y coordinate."
      ;; Fetch ruler
        ;; Deduce ruler direction
        (destructuringBind ( ( ruler_x0 ruler_y0 ) ( ruler_x1 ruler_y1 ) ) ruler->points
          (let ( ( direction (cond
                               ( (nearlyEqual ruler_x0 ruler_x1) 'vertical  )
                               ( (nearlyEqual ruler_y0 ruler_y1) 'horizontal)
                               ( t (error "Unable to determine ruler direction from points: %N" ruler->points))
                    (caseq direction
                      ( vertical   (dbMoveFig obj obj->cellView (list ruler_x-obj_x:0 "R0" 1)) )
                      ( horizontal (dbMoveFig obj obj->cellView (list 0:ruler_y-obj_y "R0" 1)) )
                      ( t          (error "Unsupported direction (should never happen...)")    )
                      ));caseq ;dbind
              );dbind
            ));let ;dbind
        ));letseq ;fun
    There are a few little oddities like this. There's one where the function that begins with sub and ends with string also fails - I've ended up changing code to use strncmp instead to get around this. It is what it is!
    Anyway, now the original poster has three different implementations. Hopefully one of them meets the goal or can be morphed into something that does! The original poster's code outline looks a bit as if it was generated by an LLM that didn't quite know what it was doing...
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 1 year ago in reply to Aurel B
    Greetings Aurel,
    It means a lot when you take time from your busy schedule to reply to such answers; no one can imagine :)
    I have succeeded in this quest with your help ...  The code is functioning as expected  Slight smile
    Once again thanks for warm gesture
    Have a pleasant day!
    Cheers & regards,
    Yogesh Jaiswal
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 1 year ago in reply to Andrew Beckett
    Greetings Andrew,
    Cheers & regards,
    Yogesh Jaiswal
