  3. Quantus Extraction – “Failed for runUserCmd / Status 256...
  • Views 3327
Quantus Extraction – “Failed for runUserCmd / Status 256” Error When Using Pegasus SVDB
RK202509013321
RK202509013321 over 1 year ago
While attempting to run Quantus extraction on a layout of an inverter database generated from Pegasus LVS/DRC (SVDB) for HW5, the tool terminates abnormally with the following error:
ERROR (LBRCXM-577): Failed for runUserCmd
ERROR (LBRCXM-584): Status 256
ERROR (LBRCXM-709): ***** Quantus terminated abnormally *****
Run details:
  • Tool: Cadence Quantus Extraction 23.1.1
  • Invocation: Using Pegasus SVDB as input (input_db -type pegasus)
  • Extraction type: c_only_decoupled
  • Output: -type extracted_view
  • Technology specification:
Could someone help investigate what might be causing this error?
    See Quantus terminates abnormally with ERROR (LBRCXM-577): Failed for runUserCmd
