  3. PasCdfDone errors from callbacks
  • Replies 12
  • Views 7402
BS202501273649
BS202501273649 over 1 year ago
I am using using SKILL to create a single instance and set some properties.  This code generally works fine on other PDKs but on this PDK I am sometimes seeing an error (though the error is wrapped in a warning (?!)):
WARNING* (CDF-262): Cannot call doneProc SKILL function '(apply GFcdfDone (db:0x3015251a))' because a SKILL error '*Error* PasCdfDone: failed to find valid initialization data!'.
I'll include the full transcript below but basically it creates a schematic, instantiates a single instance with `dbCreateParamInst` and then sets some parameters.  When the callbacks are invoked using `CCSinvokeCdfCallbacks` I am seeing this `PasCdfDone` error message even though I am using the flags on the `CCSinvokeCdfCallbacks` call which usually fixes that problem.
The device ends up correctly instantiated with the properties set correctly but the warning seems to imply that some part of the callback code has not executed correctly and so some parameters of the device might not be correct.
The really odd behaviour is that this is what happens the first time I run the code.  But if I do the creation and instantiation again then the error does not appear - as you can see below.
I am running this in Virtuoso IC23.1-64b.ISR15.37.   The version of CCSInvokeCdfCallbacks is CCSinvokeCdfCallbacks.il 04/25/22.17:40:23 1.19
procedure( createSchematic(pdkLibraryName libraryName cellName)
if(!ddGetObj(libraryName)
ddCreateLib( libraryName ".")
techBindTechFile( (ddGetObj libraryName) pdkLibraryName)
; Create Cellview
dbOpenCellViewByType(libraryName cellName "schematic" "schematic" "w")
procedure( createInst(cellview pdkLibraryName masterName instanceName)
let( (master instance)
master=dbOpenCellViewByType(pdkLibraryName masterName "symbol" "schematicSymbol" nil)
instance = dbCreateParamInst( cellview master instanceName 0:0 "R0" 1 )
schCheck(cellview)
dbSave(cellview)
instance
procedure( setProp(instance propName propValue)
let( (prop)
prop = dbSearchPropByName(instance propName)
if( prop then
dbReplaceProp(instance propName "string" propValue)
else
dbCreateProp(instance propName "string" propValue)
cellview = createSchematic("foundryLib" "testLib" "testCell")
instance = createInst(cellview "foundryLib" "foundryCell" "I0")
setProp(instance "dimensionMode" "FingerWidth")
setProp(instance "l" "50n")
setProp(instance "wf" "110n")
setProp(instance "n" "1")
CCSinvokeCdfCallbacks(cellview ?callInitProc t ?useInstCDF t ?order list( "dimensionMode" "wf" "l" "n"))
createSchematic
createInst
setProp
db:0x30152d9a
INFO (SCH-1170): Extracting "testCell schematic"
Warning: Pin "b" on instance "I0": floating input/output.
Warning: Pin "s" on instance "I0": floating input/output.
Warning: Pin "g" on instance "I0": floating input.
Warning: Pin "d" on instance "I0": floating input/output.
db:0x3015251a
db:0x30151b9f
db:0x30151ba0
db:0x30151ba1
db:0x30151ba2
t
*WARNING* **Info** when Finger Length is "0.050u", maximum allowable Finger Width is "35.000u"
*WARNING* **Info** when Finger Width is "0.110u", maximum allowable Finger Length is "10.000u"
*WARNING* (CDF-262): Cannot call doneProc SKILL function '(apply GFcdfDone (db:0x3015251a))' because a SKILL error '*Error* PasCdfDone: failed to find valid initialization data!'.
t
instance = createInst(cellview "foundryLIb" "foundryCell" "I0")
db:0x30152d9a
db:0x30151d9a
db:0x3015181f
db:0x30151820
db:0x30151821
db:0x30151822
t
t
    Andrew Beckett over 1 year ago +1
    You're using an up-to-date enough version of my callback-calling code, so I think you should just omit the ?useInstCDF t argument. It by default (nowadays) uses the actual effective CDF data (usually,…
  • BS202501273649
    BS202501273649 over 1 year ago in reply to Andrew Beckett +1
    Thanks for the quick response! I took out the ?useInstCDF t argument and that didn't prevent the problem. I guess we should remove that from our code anyway but it doesn't seem to be the issue here.…
    Andrew Beckett over 1 year ago in reply to BS202501273649 +1
    BS202501273649 said: I'll PM you with the PDK specifics so you can try to reproduce You'll need to send me a friend request so you can do that (note, this is not an open invitation to others to do this…
  • BS202501273649
    No that's a different issue - with GF.  This TSMC one is (I think) completely dealt with by removing the useInstCDF parameter so maybe does not need a response.
    I think there's a bug in the code if you pass ?useInstCdf t as it also partially uses the cell CDF. It probably is better if you only use ?useInstCdf t together with ?useCellCdf nil - but overall it's better to just omit the ?useInstCdf t, which is what I'd do...
    I will aim to fix the bug with this combination (which is mostly there still for legacy reasons) at some point, but it's not something I'm likely to get to in the next week or so.
    I'd encourage you to just omit the ?useInstCdf t - it shouldn't be needed nowadays.
