  3. PasCdfDone errors from callbacks
  • Replies 12
  • Views 7397
BS202501273649
BS202501273649 over 1 year ago
I am using using SKILL to create a single instance and set some properties.  This code generally works fine on other PDKs but on this PDK I am sometimes seeing an error (though the error is wrapped in a warning (?!)):
WARNING* (CDF-262): Cannot call doneProc SKILL function '(apply GFcdfDone (db:0x3015251a))' because a SKILL error '*Error* PasCdfDone: failed to find valid initialization data!'.
I'll include the full transcript below but basically it creates a schematic, instantiates a single instance with `dbCreateParamInst` and then sets some parameters.  When the callbacks are invoked using `CCSinvokeCdfCallbacks` I am seeing this `PasCdfDone` error message even though I am using the flags on the `CCSinvokeCdfCallbacks` call which usually fixes that problem.
The device ends up correctly instantiated with the properties set correctly but the warning seems to imply that some part of the callback code has not executed correctly and so some parameters of the device might not be correct.
The really odd behaviour is that this is what happens the first time I run the code.  But if I do the creation and instantiation again then the error does not appear - as you can see below.
I am running this in Virtuoso IC23.1-64b.ISR15.37.   The version of CCSInvokeCdfCallbacks is CCSinvokeCdfCallbacks.il 04/25/22.17:40:23 1.19
procedure( createSchematic(pdkLibraryName libraryName cellName)
if(!ddGetObj(libraryName)
ddCreateLib( libraryName ".")
techBindTechFile( (ddGetObj libraryName) pdkLibraryName)
; Create Cellview
dbOpenCellViewByType(libraryName cellName "schematic" "schematic" "w")
procedure( createInst(cellview pdkLibraryName masterName instanceName)
let( (master instance)
master=dbOpenCellViewByType(pdkLibraryName masterName "symbol" "schematicSymbol" nil)
instance = dbCreateParamInst( cellview master instanceName 0:0 "R0" 1 )
schCheck(cellview)
dbSave(cellview)
instance
procedure( setProp(instance propName propValue)
let( (prop)
prop = dbSearchPropByName(instance propName)
if( prop then
dbReplaceProp(instance propName "string" propValue)
else
dbCreateProp(instance propName "string" propValue)
cellview = createSchematic("foundryLib" "testLib" "testCell")
instance = createInst(cellview "foundryLib" "foundryCell" "I0")
setProp(instance "dimensionMode" "FingerWidth")
setProp(instance "l" "50n")
setProp(instance "wf" "110n")
setProp(instance "n" "1")
CCSinvokeCdfCallbacks(cellview ?callInitProc t ?useInstCDF t ?order list( "dimensionMode" "wf" "l" "n"))
createSchematic
createInst
setProp
db:0x30152d9a
INFO (SCH-1170): Extracting "testCell schematic"
Warning: Pin "b" on instance "I0": floating input/output.
Warning: Pin "s" on instance "I0": floating input/output.
Warning: Pin "g" on instance "I0": floating input.
Warning: Pin "d" on instance "I0": floating input/output.
db:0x3015251a
db:0x30151b9f
db:0x30151ba0
db:0x30151ba1
db:0x30151ba2
t
*WARNING* **Info** when Finger Length is "0.050u", maximum allowable Finger Width is "35.000u"
*WARNING* **Info** when Finger Width is "0.110u", maximum allowable Finger Length is "10.000u"
*WARNING* (CDF-262): Cannot call doneProc SKILL function '(apply GFcdfDone (db:0x3015251a))' because a SKILL error '*Error* PasCdfDone: failed to find valid initialization data!'.
t
instance = createInst(cellview "foundryLIb" "foundryCell" "I0")
db:0x30152d9a
db:0x30151d9a
db:0x3015181f
db:0x30151820
db:0x30151821
db:0x30151822
t
t
    Andrew Beckett over 1 year ago +1
    You're using an up-to-date enough version of my callback-calling code, so I think you should just omit the ?useInstCDF t argument. It by default (nowadays) uses the actual effective CDF data (usually,…
  • BS202501273649
    BS202501273649 over 1 year ago in reply to Andrew Beckett +1
    Thanks for the quick response! I took out the ?useInstCDF t argument and that didn't prevent the problem. I guess we should remove that from our code anyway but it doesn't seem to be the issue here.…
    Andrew Beckett over 1 year ago in reply to BS202501273649 +1
    BS202501273649 said: I'll PM you with the PDK specifics so you can try to reproduce You'll need to send me a friend request so you can do that (note, this is not an open invitation to others to do this…
    You're using an up-to-date enough version of my callback-calling code, so I think you should just omit the ?useInstCDF t argument. It by default (nowadays) uses the actual effective CDF data (usually, unless you tell it not to) and not the "lookalike" approach I used in the past - that's only used for emulating the cdfgForm if needed (and nothing in the messages above suggests it is).
    If that doesn't work, can you let me know which GF PDK you're using and an affected device? Then I can test it.
    By the way, in your setProp function, you don't really need to use dbReplaceProp if it exists and dbCreateProp if it doesn't; you can always use dbReplaceProp (this works if the property exists or not). Needless to say, we recommend writing functions with a unique prefix to avoid clashes - names such as setProp, createSchematic etc are likely to clash with other code which may have different behaviour (that's just something I like to mention before you get burnt by it!)
  • BS202501273649
    I'll PM you with the PDK specifics so you can try to reproduce.  Thanks again!  And for the code improvements.
    You'll need to send me a friend request so you can do that (note, this is not an open invitation to others to do this - I normally decline direct friend requests as technical questions should be asked in the forums rather than to me directly - I don't have the capacity to deal with direct questions).
    Happy to investigate in this case, so please do contact me!
    Andrew Beckett over 1 year ago in reply to Andrew Beckett
    The particular PDK in question was storing some information on the cdfgForm during the formInitProc and then needing to access it not only during callbacks (which was handled) but also during the doneProc (which was not). That together with some trickery which meant that they discarded my faked cdfgForm and created their own (which wouldn't work in all circumstances, but that's beside the point). Anyway, I've now updated the code in the article How to call CDF callbacks procedurally from SKILL to update CDF parameters? (v1.21)
    Please download, and then call using (in your code above) - note the ?setCdfgForm t that you should add:
    CCSinvokeCdfCallbacks(cellview ?callInitProc t ?setCdfgForm t ?order list( "dimensionMode" "wf" "l" "n"))
  • BS202501273649
    Thanks very much. Super prompt and effective support!
  • BS202501273649
    So this new code definitely fixed the issues in this PDK but it also seems to have caused issues in another PDK (tsmc CRN22ULL)
    I am calling the code with something like this where `callbacks` is a list of the relevant property names.
    (CCSinvokeInstCdfCallbacks
                    instance ?callInitProc t ?useInstCDF t ?setCdfgForm t
                    ?order callbacks
    But it seems like the callbacks are not executing.  It's entirely possible I am doing something wrong but I can't see what it is at the minute.  I'm going to try to construct a more minimal example but that's going to take a little time ...
  • BS202501273649
    BS202501273649 over 1 year ago in reply to BS202501273649
    So here is my more minimal example:
    ; Create Cellview
    schCheck(cellview)
    dbSave(cellview)
    instance
    cellview = createSchematic("tsmcN22" "testLib" "testCell")
    instance = createInst(cellview "tsmcN22" "nch_18_mac" "I0")
    CDF = cdfGetInstCDF(instance)
    param = cdfFindParamByName(CDF "fingers")
    param->value = "2"
    param = cdfFindParamByName(CDF "Wfg")
    parmm->value = "320n"
    ?order '("fingers" "Wfg")
    If the callbacks had run we would expect to find the total width (CDF parameter "w") to be "640n".    Instead we get
    cdfFindParamByName(CDF "w")->value
    "320n"
  • BS202501273649
    Not completely sure what's going on but it looks at first sight like it might work if I omit the `?useInstCDF t` parameter.
  • BS202501273649
    So I guess that goes back to your very first response - I should not be using that flag.   It is in my code from an inherited codebase of venerable age and so I can't explain why it's there and can probably remove it - let's hope so!
    I see you've asked this again in a separate post, so I'll deal with it there
