  3. Setting the value of a CDF parameter
  • Views 5645
BS202501273649
BS202501273649 over 1 year ago
I am using SKILL to update the properties on an instance.
I am probably missing something obvious but I don't completely understand the difference between the properties as accessed directly on the instance and the CDF parameters defining those same properties.  In particular, for one PDK at least, I am seeing a difference when I set the value via the property versus setting it via the CDF parameter.
In other words between
dbReplaceProp(instance prop_name type(newPropValue) newPropValue)
and
CDF = cdfGetInstCDF(instanceDB)
param = cdfFindParamByName(CDF prop_name)
param~>value = newPropValue
In both cases the property seems to being set "correctly": it appears correctly in the dialog in Virtuoso.  But I am seeing some subtle differences in what is saved in OA.  In particular, this is a boolean and I am trying to make it False by setting it to nil.   In the second case that is indeed what happens but in the first case the property contains an AppPropertyValue containing the bytes "nil" which seems like it might be wrong.
So I'm guessing the second form of the code is what I want but I'm not really sure why.
  • Aurel B
    Aurel B over 1 year ago
    When you set the value like you do, you will not properly trigger the CDF callbacks, you might end up with corrupted instances.
    (They might have values that are not supported. You could probably not use the same values inside the GUI).
    There are plenty of questions about this and many articles on the support site as well...
    Here is one:
    How to change or update CDF parameter value of an instance using SKILL or GUI
  • BS202501273649
    BS202501273649 over 1 year ago in reply to Aurel B
    In both cases I was subsequently executing the callback.  It was specifically the difference between changing the property values and the parameter value that I was interested in.
    I guess the way the parameter value is saved in the property value depends on the type of the CDF parameter and so we need the CDF parameter itself to set the property rather than setting the property directly but I wondered if there was more information about the way the CDF parameter is saved as a property on the instance.
    In this case it's not callback related as Aurel suggested (although that can be a problem in general). It's that using dbRepaceProp in the manner you have (using the type of the SKILL value to determine the property type) will not work correctly (probably) if you have a value of nil. In SKILL, nil is actually an empty list and is used to represent false - there is no boolean type in SKILL - anything other than nil is true. So type(nil) is list. You'd be creating a list property with an empty list (which is a custom AppProp in OA), rather than a "boolean" property type with value nil (false). If you passed "boolean" as the third arg to dbReplaceProp it would store it a a boolean property, not a list.
    With the CDF-based approach, it knows the type of the CDF parameter, and hence will set the appropriate type of the instance property used to store it.
  • BS202501273649
    BS202501273649 over 1 year ago in reply to Andrew Beckett
    Ah of course!   The type is wrong - I need to use the CDF parameter type not the type of the data being set when it is nil.  Thanks!  Setting it via the CDF parameter is actually fine and what I am doing but I just needed to understand better.
