  3. Any known limitations of geIsPointInsidePolygon or CCSP...
  • Replies 11
  • Subscribers 150
  • Views 5743
Any known limitations of geIsPointInsidePolygon or CCSPointInPolygon
RK56
RK56 over 1 year ago
I'm trying to find if a point is inside a polygon as shown in the image below.  Both the functions (geIsPointInsidePolygon & CCSPointInPolygon) fail to test correctly the pink locations in the image for inside. To check if it is due to the polygon, I chopped the lower half to simplify and then the functions test correctly. While I can infer that such complicated polygons are not supported, I could not find what kind of polygons are acceptable.
Can someone here help me to find?
I'm using IC23.1-64b Version of Virtusos
Ram
  • Aurel B
    Aurel B over 1 year ago in reply to RK56
    Another solution that might work as well is to use ABE functions (boolean operations).
    You can build ABE layers using abeLayerFromCellView to get all shapes from a layer in a cell view.
    Or you can use abeNewLayer and abeLayerOrPtArray to create a layer from polygons.
    Then you can use abeLayerInside (you can also do many other checks: abeLayerAndNot, abeLayerXor, ...)
    Then you just have to check if the resulting layer area is 0.
    It might be easier to debug, as you can always display the result of any generated layer into a highlight set.
    It requires some ABE knowledge and to write a bit of of wrapping code but it's definitely worth it.
    Be aware that it is limited to 45° angles (which seems to be OK in your case)
