  3. Asign net names to the instance terminals
  • Views 2373
EA1000
EA1000 over 1 year ago
Hi All,
While working on my layout SKILL scripting task, I encountered an issue assigning terminal names to a specific instance.
By default, when instantiating a MOS device, its terminals (S, D, G, B) are set to nil. I would like to assign them properly, for example:
  • Source → net_S
  • Drain → net_D
  • Gate → net_G
  • Bulk → net_B
I’m currently stuck on how to implement this correctly in SKILL.
Please help me. Thank you in advance
EP
    You need to use dbCreateInstTerm (or dbCreateConn) to create each of the invidual instance terminal connections (you'll need to create the nets too - i.e. using dbMakeNet or dbCreateNet).
