  3. Form buttons
  • Views 2745
Form buttons
AE202502048334
AE202502048334 over 1 year ago
Hi all, I'm trying to create a from with user defined buttons.
I'm trying the following code but can't get it to work:
main = hiCreateFornLayout('main_layout ?items () )
form = hiCreateLayoutForm(
             'myForm
             'myTitle
             ?buttonLayout '(Empty (btn1 btn1_CB()) (btn2 btn2_CB()) (Close hiFormClose()))
hiDisplayForm(form)
The part I'm having issues with is buttonLayout part, I can't seem to understand the syntax in the DOCs
    Andrew Beckett over 1 year ago +1
    There's a typo in the documentation (you originally had '('Empty ...) but I see you've corrected the mistake). Now the issue is that the callbacks need to be either an unquoted name of a function or a…
    There's a typo in the documentation (you originally had '('Empty ...) but I see you've corrected the mistake). Now the issue is that the callbacks need to be either an unquoted name of a function or a string. So something like this:
    main = hiCreateFormLayout('main_layout ?items () )
                 'myForm
                 "myTitle"
                 main
                 ?buttonLayout '(Empty (myFun1 "myFun1()") (myFun2 "myFun2()") (Close hiFormClose))
    hiDisplayForm(form)
    The first two buttons have a full function call expression to invoke, and the third is the name of the function to call (and this gets passed the form id).
  • AE202502048334
    AE202502048334 over 1 year ago in reply to Andrew Beckett
    Thank you so much Andrew, It worked !
