  3. Get Coordinates of highlights
  • Subscribers 150
  • Views 2423
RK56
RK56 11 months ago
My DRC tool creates highlights in the layout window. I believe they are created using highlight sets. Is it possible to read the coordinates of the highlight sets in a layout window? I dont know the highlight setID as they are created by some 3rd part tool. My plan is to retrieve coordinates from the highlight shapes and then provide them to leComputeDensity so that I can easily measure the densities post fix and before a DRC run.
Ram
  • Aurel B
    Aurel B 11 months ago
    This is a shot in the dark, but have you tried geGetCurrentHilightSet or geGetCurrentWindowHilightSet ?
    You can probably combine them with gePopHilightStack or gePopWindowHilightStack to get the highlight set you want.
    (I am not familiar with those functions but they seem capable of doing what you are looking for.)
    Andrew Beckett 11 months ago in reply to Aurel B
    I didn't see the original post until Aurel's reply.
    Unfortunately geGetCurrentHilightSet (and the window equivalent) only work if:
    1. The hilight set was created with the notGlobal argument set to t, and
    2. It was pushed on to the stack with gePushHilightStack (this is needed for it to be come visible)
    In my experience, hilight sets are usually created as global (I've never used the push/pop APIs) and so these won't help you. The DRC tool might store the hilight set object somewhere (for example, I usually store it as a window property to make it easy to retrieve and to allow different hilight sets in different windows without needing some other storage mechanism). So maybe it is there?
    The best thing would be to ask whoever created the DRC tool for a means of retrieving it.
  • RK56
    RK56 11 months ago in reply to Andrew Beckett
    Thank you Aurel and Andrew for your inputs. I could not get it work with the above functions. Maybe it is a case as Andrew mentioned.
