  3. Problem Updating vtType Parameter When Swapping NMOS and...
  • Subscribers 150
  • Views 2713
Problem Updating vtType Parameter When Swapping NMOS and PMOS in SKILL Code
KH202511117250
KH202511117250 11 months ago
Hello Cadence Community,
I’m working on a SKILL procedure to swap device cellNames between nmos and pmos while preserving and updating the vtType parameter.
I'm using IC23.1 version
Goal:
  • If the device is nmos, store its parameter "vtType" in variable p, change cellName to pmos, and set vtType to pmodel.
  • If the device is pmos, store its parameter "vtType" in variable n, change cellName to nmos, and set vtType to nmodel.
Code:
procedure(paratest()
  let((cv a b c d e p n pmodel nmodel newMaster newcdf)
    cv = geGetEditCellView()
    foreach(inst cv~>instances
      a = inst~>cellName
      b = inst~>libName
      c = inst~>viewName
      when(a == "nmos"
        foreach(param cdfGetInstCDF(inst)~>parameters
          when(param~>name == "vtType"
            p = param~>value
            printf("Current value of %s vtType value is %s\n" a p)
            pmodel = if(p == "nvt"
                       then
                         "pvt"
                       else
                         if(p == "nhvt"
                           then
                             "phvt"
                           else
                             if(p == "nulvt"
                               then
                                 "pulvt"
                               else
                                 p
        newMaster = dbOpenCellViewByType(b "pmos" c)
        when(newMaster
          inst~>master = newMaster
          d = inst~>cellName
          when(d == "pmos"
            newcdf = cdfGetInstCDF(inst)
            foreach(param newcdf~>parameters
                param~>value = pmodel
                printf("set vtType for %s to: %s\n" d pmodel)
      when(a == "pmos"
            n = param~>value
            printf("Current value of %s vtType value is %s\n" a n)
            nmodel = if(n == "pvt"
                       then
                         "nvt"
                       else
                         if(n == "phvt"
                           then
                             "uhvt"
                           else
                             if(n == "pulvt"
                               then
                                 "nulvt"
                               else
                                 n
        newMaster = dbOpenCellViewByType(b "nmos" c)
        when(newMaster
          e = inst~>cellName
          when(e == "nmos"
                param~>value = nmodel
                printf("set vtType for %s to: %s\n" e nmodel)
Observed Behavior:
  • Output in ciw:
    paratest()
    Current value of nmos vtType value is nvt
    set vtType for pmos to: pvt
    Current value of pmos vtType value is pvt
    set vtType for nmos to: nvt
    set vtType for nmos to:nvt
    Layout output:
    Only cellNames were changing..but vtType parameter is setting "Invalid Model"
    FYI, "Invalid Model" is also included in the list of vtType parameters.
Question:
  • Why is the vtType assignment failing and defaulting to "Invalid Model"?
  • Is there a better approach to update instance parameters after changing the master?
Any guidance or best practices would be greatly appreciated!
    Andrew Beckett 11 months ago
    I reformatted your code in your post to give me a chance of understanding it. Without indentation, it was illegible.
    My guess is that there's a CDF initProc for these components which is doing some validation of the model and resetting it to "Invalid Model". What PDK are you using?
    Rather than using edit properties to show the property values, can you select the instance and do:
    car(geGetSelSet)~>vtType
    and report what you get (disable the property assistant in the schematic editor too if that's enabled). If that's showing the expected value, that pretty much confirms that it must be a CDF initProc.
  • AR202509246930
    AR202509246930 11 months ago in reply to Andrew Beckett
    it seems that a string value was assigned to the vtType parameter, which actually supports multiple options—likely through a drop-down menu. Since the code only provides a single string value, it isn’t being recognized and defaults to the predefined value.
    Let assume if it's a drop-down menu
    Assuming it’s a drop-down menu, how can we identify the function name and modify the code accordingly?
    Andrew Beckett 11 months ago in reply to AR202509246930
    I don't understand what you're asking. The CDF is presumably defined as a cyclic parameter type and that will have a ~>choices slot to indicate the available choices. That's what makes it a "drop-down menu" in the edit properties form. There's no "function name" here, and the chosen value would be stored on the instance as a string property.
    It is (as I said) most likely to be caused by a formInitProc in the CDF (you can check that function with cdfGetInstCDF(inst)~>formInitProc if it's specified). You didn't answer my question about which PDK you're using.
  • AR202509246930
    Tried this leUpdateInstanceCDFParameterValues(cv inst list(list("vtType" pmodel)))... it's working.
    Thanks Andrew
