  3. Capture errset stdout into a variable
  • Views 2661
Trevor F
Trevor F 11 months ago
Good evening, I'm attempting to make a "function linter" to run a couple generic test cases through a function to ensure it succeeds a baseline.
My current workflow is running them through an errset. I see that errset has a t/nil property for printing the error, but I need access to the actual error string. Is there a solid way to redirect the stdout into a variable? I can see redirecting it into a file and reading it into a variable but that route seems erroneous.
Example:
procedure(test(x) unless(x == 1 error("generic error"))
res = errset(apply('test list(2)) t)
prints: *Error* generic error
Thanks, Trevor
  • mbracht
    mbracht 11 months ago in reply to Trevor F +2
    Hi, The actual error message is available in the symbol property errset.errset. Technically it is a list with the 5th element being a sublist with it's first element being the actual error as a string…
  • Trevor F
    ipcProcess is another prospect I suppose?
  • mbracht
    The actual error message is available in the symbol property errset.errset. Technically it is a list with the 5th element being a sublist with it's first element being the actual error as a string...try this:
    (unless (errset 1/0) (println (car (nth 4 errset.errset))))
    regards
    Max
    • Vote Up +2 Vote Down
  • Trevor F
    Trevor F 11 months ago in reply to mbracht
    That is perfect thank you!
  • p94todorov
    p94todorov 11 months ago in reply to mbracht
    Thank you, Max!
    I've been looking for this for such a long time, but always managed to do it in some other way. I didn't knew that this list entry exists and can be accessed so easily! I will keep this in the back of my head from now on.
    Best Regards,
    Petar
