  3. How do I rename a net which does not have net attribute...
  • Replies 8
  • Subscribers 152
  • Views 3605
How do I rename a net which does not have net attributes
Ganesh B
Ganesh B 11 months ago
Hi, How do I rename a net which does not have a net attribute, ie, netId~>net=nil using Skill. dbRenameNet works only when net has some names already.
    Andrew Beckett 11 months ago
    It's unclear what you are doing. If netId is a net object, it wouldn't have a net attribute, so doing netId~>net would be looking for a user-defined property called net, and if not present it would return nil.
    What does netId~>objType show?
  • LE202511197417
    LE202511197417 11 months ago
    You can use dbSetName on the net object itself, even if it has no existing name, to assign a new name.
    Andrew Beckett 11 months ago in reply to LE202511197417
    No you can't. There's no such function as dbSetName and there's no such thing as a net object without a name.
  • Ganesh B
    Ganesh B 11 months ago in reply to Andrew Beckett
    geGetSelectedSet()~>??
    ((db:0x74142d69 cellView db:0x7047971a objType "path"
    prop nil bBox
    ((186.112 43.828)
    (186.952 43.868)
    ) children
    nil groupMembers nil isAnyInst nil
    isShape t matchPoints nil net
    nil parent nil pin nil
    purpose "drawing" textDisplays nil assocTextDisplays
    nil markers nil figGroup nil
    isUnshielded nil shieldedNet1 nil shieldedNet2
    nil layerName "M4" layerNum 34
    lpp
    ("M4" "drawing") connRoutes nil routeStatus
    "normal" beginExt 0.0 endExt 0.0
    nPoints 2 points
    ((186.112 43.848)
    (186.952 43.848)
    ) pathStyle
    "truncateExtend" width 0.04
    Andrew Beckett 11 months ago in reply to Ganesh B
    OK, so you have a figure selected (a path in this case) - the object you are looking at is not a "net".
    You'd need to do:
    cv=geGetEditCellView()
    net=dbMakeNet(cv "myNetName") ; whatever you want it to be
    ; either add all of the selected shapes to the net:
    foreach(fig geGetSelSet()
      dbAddFigToNet(fig net)
    ; or just the first
    ; dbAddFigToNet(car(geGetSelSet()) net)
    Note that the reason I used dbMakeNet rather than dbCreateNet is that dbMakeNet works if the net already exists.
  • Ganesh B
    Thanks Andrew, it worked Slight smile
  • Ganesh B
    Ganesh B 11 months ago in reply to Ganesh B
    Hi Andrew, I got some problem when I was handling bus names.  Idea is to select the paths and automatically assign the netnames like sig<0> sig<1>, sig<2>, sig<3>  ..... so on,  ascending or descending order.
    busname="sig<0>"
    first_bit=atoi(nth(0 parseString(nth(1 parseString(busname "<")) ">")))
    signame=nth(0 parseString(busname "<"))
    count=first_bit
    sig_name=concat(signame "<" count ">")
    net=dbMakeNet(cv sig_name)
    count=count+1
    );foreach
    Error:
    Entering new debug toplevel due to error:
    *Error* eval: unbound variable - sig
    *Error* dbMakeNet: Invalid net name - sig\<0\>
  • Ganesh B
    Hi, Issue got fixed now. Let me know if any modifications are needed in the code, Thanks.
    cv=geGetWindowCellView()
    busname="sig<0>"
    count=first_bit
    sigName_s=sprintf(nil "%s" sig_name)
    net=dbMakeNet(cv sigName_s)
    fig~>route~>objects=remove(fig fig~>route~>objects)
    count=count+1
    );foreach
