  3. Export transient waveform of ADE Explorer Testbench with...
  • Subscribers 152
  • Views 4871
Export transient waveform of ADE Explorer Testbench with Ocean
MarkyMark
MarkyMark 11 months ago
Hi there,
I'm currently trying to automate data generation for transient simulation with multi-dimensional sweeps using ADE Explorer testbench. I have a test defined for transient simulation. I was trying to modify the Ocean script (obtained from file => save as ocean script) by a couple additional lines to directly export the waveforms (voltage/current vs time) after the simulations have finished.
To generate the results before (and export them to a csv for all variable permutations) I was using "plot all" then selected all curves, then export and save as a csv. This gives me two columns (one for X = time, one for Y = voltage/current, for a given combination of variables). For large amount of sweep this becomes unpractical, which is why I also why I want to automate it.
I didn't figure out the commands to export specific signals (lets say /OUT and /IN) to a csv like that, does anyone know how to do it?
Regards
This is the basic code I am using (corners and sweeps not included here for simplicity):
;====================Set to Maestro mode assembler =============================
ocnSetXLMode("assembler")
;====================== Tests setup ============================================
;---------- Test "test_tran" -------------
ocnxlBeginTest("tran_prbs_in")
simulator( 'spectre )
design( "lib" "cell" "view")
analysis('tran ?stop "2n" ?errpreset "conservative" ?step "1p"
?maxstep "1p" ?minstep "1p" )
saveOption( 'save "all" )
temp( 27 )
ocnxlOutputSignal( "/IN" ?plot t ?save t)
ocnxlOutputSignal( "/OUT" ?plot t ?save t)
ocnxlEndTest() ; "tran_prbs_in"
;====================== Run command ============================================
ocnxlRun( ?mode 'sweepsAndCorners ?nominalCornerEnabled nil ?allCornersEnabled t ?allSweepsEnabled t)
ocnxlOutputSummary(?exprSummary t ?specSummary t ?detailed t ?wave t)
ocnxlOpenResults()
saveFile = "dummy_filename.csv"
* here I would like some code to export the aforementioned data* :)
;====================== End XL Mode command ===================================
ocnxlEndXLMode("assembler")
    Andrew Beckett 11 months ago in reply to Trevor F +1
    A simpler approach is probably just to add an output with an expression: awvSaveToVCSV (list(expr1 expr2 expr3) "./someFile.vcsv") where expr1 expr2 etc could be VT("/sig1") VT("/sig2") etc. You could…
    Trevor F said: Out of curiosity, why is a similar procedure not defined under the dr functions? That's where I was looking when I decided to just create my own It's really just about the hierarchy of…
  • Trevor F
    Trevor F 11 months ago
    I'm not too familiar with ocnxl commands but assuming it follows the usual process and you are able to get your "/IN" and "/OUT" as waveform objects (drIsWaveform(VT("/IN") == t) then you can write a quick waveformToCsv script. This is a barebones one I made that should work. I'd add more error checking if I were to use it.
    procedure(waveformToCSV(wave file_path)
    let(( xvec yvec len fp )
    xvec = drGetWaveformXVec(wave)
    yvec = drGetWaveformYVec(wave)
    when( or( null(xvec) null(yvec))
    error("invalid waveforms")
    len = min( drVectorLength(xvec) drVectorLength(yvec))
    fp = outfile(file_path)
    unless(portp(fp)
    error("couldnt open file")
    for( i 0 len-1
    fprintf(fp "%.15g,%.15g\n" drGetElem(xvec i) drGetElem(yvec i)
    close(fp)
    awvSaveToVCSV(list(expr1 expr2 expr3) "./someFile.vcsv")
    where expr1 expr2 etc could be VT("/sig1") VT("/sig2") etc. You could then set the evalType of this output expression to "all" and it will then save the waveforms across all sweep points into a single ViVA CSV file...
  • Trevor F
    Trevor F 11 months ago in reply to Andrew Beckett
    This is definitely easier! I never knew this existed. Out of curiosity, why is a similar procedure not defined under the dr functions? That's where I was looking when I decided to just create my own.
    It's really just about the hierarchy of API layers. The dr functions are quite low-level, and don't really provide general capabilities beyond that.
