  3. verifOpenCellView
  • Views 2248
verifOpenCellView
PB202509293935
PB202509293935 11 months ago
I have created a verifier cell view and generated a batch script to re-run the verifier. However , if i invoke script , it shows below error.
*WARNING* (VERIFIER-5006): verifOpenCellView : (VERIFIER-1012): Cannot open the cellview 'ip_lib/tb_adcmuxldo/verifier_adc' for reading because it does not exist.
Ensure that you specify a valid 'verifier' cellview that exists.
I manually verified the cell view and it exist. Could you please help me resolve this issue.
Thanks & Regards,
Praveen
    Andrew Beckett 11 months ago
    Praveen,
    How are you running the batch script? Is it possible that you're not running in the correct location that it finds the cds.lib file and then the libraries, or that there's an environment variable needed to locate the library in the cds.lib?
    Which IC sub-version are you using (either Help->About in any window, or typing "virtuoso -W" from the UNIX command line)?
  • PB202509293935
    PB202509293935 11 months ago in reply to Andrew Beckett
    I invoked the commnad from cdslib folder, its working fine now.
    Thanks for your quick help.
    Best Regards,
    Praveen
