  3. How to load and execute a "file.il"
  • Views 1621
PO202512012325
PO202512012325 11 months ago
Hi Everyone,
I am trying to execute a simple LIST request, see below.  When I load the file into the CIW a cell.txt is created but it is empty, it does not run on the opened cell.
Does anyone have some guidance?
Thanks very much,
Patrick
let((file)
     file=outfile("cell.txt")
     foreach(obj geGetSelSet()
          when(obj~>objType=="inst"
             fprintf(file "%s\n" obj~>name)
     close(file)
    Andrew Beckett 11 months ago
    Provided that you have some instances selected, this should work. One thing to check - what is the order of the paths in the return value of getSkillPath() ? If this doesn't have "." at the beginning, then the outfile("cell.txt") may be creating a file somewhere other than the working directory, because the files are resolved using the SKILL path. You could use outfile("./cell.txt") to force it to the working directory instead - maybe that's it?
