  3. Control waveform style options within a waveform family
  • Views 2810
SK202511261716
SK202511261716 10 months ago
Hello all,
I'm working on a SKILL utility and I have a question about plotting options. I'm plotting three waveforms at once, with different colours and line styles. In the following examples, ywaves is a list of waveforms returned from drCreateWaveform.
Now, if I run
awvPlotWaveform(awvCreatePlotWindow() ywaves ?colors list(0xFF0000 0xFF0000 0xFF0000) ?lineStyle list(Dashed Solid Dashed))
This works well - my waves are plotted correctly: all red, with alternating style.
Here's the tricky bit: for this application it would be helpful if the waves were grouped as a family.
myfam = famCreateFamily("myvar" 'double)
i = 0
foreach(wv ywaves
    famAddValue(myfam i wv)
    i = i + 1
Again, this works. Running awvPlotWaveform(awvCreatePlotWindow() list(myfam)) plots the waves as a family, as you would expect. The style is solid and the colours random, since I didn't specify that information.
Now my question is, can I combine these two things? I.e. Can I keep these waveforms grouped as a family, while controlling their colour and line style individually?
awvPlotWaveform(awvCreatePlotWindow() list(myfam) ?color list(0xFF0000) ?lineStyle '(Dashed)) has no effect: the colours are still random and the line style solid.
My tool version is IC6.1.8-64b.83
Stafford
    Andrew Beckett 10 months ago +1
    Stafford, I don't know how to do this (other than plotting the individual leaves separately).You can change the colors after the event using the "Customise Trace Group" assistant, but getting them right…
    Stafford,
    I don't know how to do this (other than plotting the individual leaves separately).You can change the colors after the event using the "Customise Trace Group" assistant, but getting them right up front I'm not sure about. I'll ask our R&D team.
  • SK202511261716
    SK202511261716 10 months ago in reply to Andrew Beckett
    Thanks Andrew. If it can't be done I'll forgo the custom styles in favour of the family and I should still be able to manage. Looking forward to hearing the response from R&D
