  3. Running Python function from ipcBeginProcess
  • Views 1637
CG20240827312
CG20240827312 10 months ago
I want to run the following command using ipcBeginprocess ()
python3 -c "import sys; sys.path.append('path/to/directory'); from myscript import my_func; my_func()" arg1 arg2
when I try to run this using ipcBeginprocess it gives invalid token 'path. But when I run using sh() it works perfectly but in terminal
Following is a snippet of my code:
arg1=cv~>cellName
arg2=cv~>libName
Process= strcat("python3 -c " "/"" "import sys; sys.path.append('path/to/directory'); from myscript import my_func; my_func()" "/"" arg1 " " arg2)
Pid=ipcBeginprocess (Process)
Thanks for helping.
