  3. Form with size adjustable automatically
  • Views 2810
Martinsh
Martinsh 9 months ago
Create a form to display some text. The text content may more or less. Make the form size adjust automatically based on the amount of text content. The maximum size of the form should be limited by the screen size. If too more text to be displayed on the form with maximum form size, show scroll bar. Please help on this.
It's like the form displayed with hiDisplayAppDBox(). But the dialog Box size can't be limited by the screen size when large amount of text displayed. It will go out of screen and no scroll bar.
Thanks!
    Andrew Beckett 9 months ago
    This is sort of a layout form created with hiCreateFormLayout/hiCreateVerticalBoxLayout/hiCreateHorizontalBoxLayout/hiCreateGridLayout together with hiCreateLayoutForm. The field itself could be hiCreateMLTextField or hiCreateHypertextField. Scrollbars can then be added automatically as needed depending on whether the window fits the contents or the screen.
    This then allows the form to be resizable (if done right) and you can constrain it in various ways. However, I don't think we offer the ability to set a better sizeHint or policy to adjust the size based on the content size (there's an enhancement CCR for that #2740570 ). Potentially you could adjust the size based on knowledge of the content, but then you need to also know about the font used as the hi.*Size functions are based on pixels.
    There isn't really a way of doing this fully automatically that the form resizes based on the text contents, I believe (I may be mistaken of course...)
  • Martinsh
    Martinsh 9 months ago in reply to Andrew Beckett
    Dear Andrew,
    The form of ddsHiRefresh() is what I want. The form size will fit the content that will be refreshed. If too more refersh items to displayed on the form, vertical scroll bar will displayed. Can you tell me how it is realized?
    Thanks!
    Andrew Beckett 9 months ago in reply to Martinsh
    That form is implemented using the old coordinate-based way of creating forms, so is not a particularly great example of having a resizable form.
    In other words, it creates all the fields using incrementing coordinates and then places them all within a scroll region:
    scrollRegion=hiCreateScrollRegion(
      ?name 'theScrollRegion
      ?fields myFIeldList
      ?rightMargin 2
      ?bottomMargin 2
      ?borderWidth 4
      ?scrollBars 'dynamic
    and then an appForm is created (hiCreateAppForm) using that scroll region.
    I can see some attempt in the code to use attachments (which is the old way of creating resizable forms with coordinate-based 2D forms), but then the attachment list that is constructed is never used (probably because in the old scheme there was a clash between having scrollbars and using attachments).
    I'd recommend using a layout form instead and just setting a sensible initial size based on the content you have added. Without knowing what you're trying to do it's hard to give a real example - you talked about "text" but the example you want to base it on is full of labels and boolean buttons, so it's not clear what your need is.
