  3. How to short all the internal nets to VSS with skill
  • Views 2403
Mooh
Mooh 9 months ago
I'm trying to short all the internal nets to VSS, but it doesn't work anyhelp please
lib = "TEST"
cell = "RES"
cv = dbOpenCellViewByType(lib cell "schematic" "" "a") ; "a" for append mode
schCreateWire(cv "draw" "full" list(0.0:0.0 0.25:0.25) 0.03 0.03 0.0)
foreach(net cv~>nets
when(net~>segments
schCreateWireLabel(car(net~>segments) "VSS" "centerCenter" "R0" "stick" t)
    Andrew Beckett 9 months ago
    Nets don't have an attribute segments so this will do nothing. Equally, your call to schCreateWireLabel has the wrong number of arguments, so even if you changed net~>segments to net~>figs then it would fail because of that.
    Finally, you may also need to run schCheck() to extract the connectivity in the schematic if you are creating wires using SKILL. So something like this would work instead:
    lib = "TEST"
    cell = "RES"
    cv = dbOpenCellViewByType(lib cell "schematic" "schematic" "a") ; "a" for append mode
    schCheck(cv)
      when(net~>figs
        schCreateWireLabel(cv car(net~>figs) centerBox(car(net~>figs)~>bBox) "VSS" "centerCenter" "R0" "stick" 0.0625 nil)
  • Mooh
    Mooh 9 months ago in reply to Andrew Beckett
    Thank you so much
