  3. Looking for alternate of dbInstQuery
  • Views 1999
Duc Loc
Duc Loc 8 months ago
Hi all,
I'm working on copying instance from a lower hierarchy to the top level and found a solution here: SKILL: How to copy all cells with a specific name in the layout hierarchy to the top level
When I tried it, dbInstQuery was unable to finish because there are millions of instances in the hierarchy. I attempted to limit it using dbInstQuery(cv cv~>bBox startLevel stopLevel), but it wasn't efficient since the instance I need is deep in the hierarchy. Is there a function that can target a specific instance? I'm also open to other suggestions.
Thank you in advance,
Loc
    Andrew Beckett 8 months ago
    Loc,
    I just wrote a different approach which traverses the hierarchy (dealing with mosaics too) which should be much faster. I plan to write this up as an article for the ASK portal too.
    /* abCopyInstsToTop.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 09, 2026
    Modified
    By
    Copy matching instances to the top cellView. Rather than using
    dbInstQuery to find all instances in the cellView, walks the hierarchy
    looking for matches instead - this will be more efficient in the
    case where there are a lot of instances in the hierarchy.
    Example usage:
    newInsts=abCopyInstsToTop(?cellName "adc_comparator_actr" ?libName "ether")
    SCCS Info: @(#) abCopyInstsToTop.il 02/09/26.11:23:26 1.1
    *        (abCopyInstsToTop [?cellView (geGetEditCellView)]         *
    *                      [?destination destCV]                       *
    *                        [?libName libName]                        *
    *                       [?cellName cellName]                       *
    *                       [?viewName viewName]                       *
    *                      [?transform transform]                      *
    *                         [?copies copies]                         *
    *   Look down through the hierarchy for any instance (or mosaic)   *
    * that matches the given libName/cellName/viewName. Note that the  *
    * match is only made on the arguments given (so if libName is not  *
    * specified, any libName will do). The destination defaults to the *
    *    top cellView started from. ?transform and ?copies are used    *
    *   internally for the recursion and would not be expected to be   *
    *               passed by a caller of the function.                *
    *     Returns a list of the instances that were created in the     *
    *                      destination cellView.                       *
    (defun abCopyInstsToTop (@key (cellView (geGetEditCellView))
                                  destination
                                  libName cellName viewName
                                  (transform list(0:0 "R0" 1))
                                  copies)
      (unless destination
        (setq destination cellView))
      ; Deal with simple instances
      (foreach inst (getq cellView instances)
               (when (equal (getq inst objType) "inst")
                 (if (and
                       (or (null libName) (equal (getq inst libName) libName))
                       (or (null cellName) (equal (getq inst cellName) cellName))
                       (or (null viewName) (equal (getq inst viewName) viewName))
                   ; then
                   (setq copies
                         (cons (dbCopyFig inst destination transform)
                               copies))
                   ; else
                   (setq copies
                         (abCopyInstsToTop
                           ?cellView (getq inst master)
                           ?destination destination
                           ?libName libName
                           ?cellName cellName
                           ?viewName viewName
                           ?transform (dbConcatTransform
                                        (getq inst transform) transform)
                           ?copies copies
      (foreach mosaic (getq cellView mosaics)
               ; Don't bother checking for complex mosaics since these
               ; don't exist in OA
               (let (master orient xy newTransform mosaicTransform)
                 (setq master
                       (getq (car (getq mosaic instanceList)) master))
                 (if (and
                       (or (null libName) (equal (getq master libName) libName))
                       (or (null cellName) (equal (getq master cellName) cellName))
                       (or (null viewName) (equal (getq master viewName) viewName))
                   ; then
                   (setq copies
                         (cons (dbCopyFig mosaic destination transform)
                               copies))
                   ; else
                   (progn
                     (setq orient (car (getq mosaic tileArray)))
                     (setq mosaicTransform
                           (dbConcatTransform
                             (dbConcatTransform
                               (list
                                 (mapcar 'minus (getq mosaic xy)) "R0" 1)
                               (list (list 0 0) orient 1))
                             (list (getq mosaic xy) "R0" 1))
                     ; Iterate over the rows and columns, flattening each
                     ; sub-instance in the simple mosaic
                     (for row 0 (sub1 (getq mosaic rows))
                          (for col 0 (sub1 (getq mosaic columns))
                               (setq xy
                                     (list
                                       (plus (xCoord (getq mosaic xy))
                                             (times col (getq mosaic uX)))
                                       (plus (yCoord (getq mosaic xy))
                                             (times row (getq mosaic uY)))
                               ; Compute the transformation of the sub-instance
                               (setq newTransform
                                     (dbConcatTransform
                                       (dbConcatTransform
                                         (list xy "R0" 1)
                                         mosaicTransform)
                                       transform))
                               ; Call recursively
                               (setq copies
                                     (abCopyInstsToTop
                                       ?cellView master
                                       ?libName libName
                                       ?cellName cellName
                                       ?viewName viewName
                                       ?transform newTransform
                                       ?copies copies
      ; Return list of new instances that were copied
      copies
  • Duc Loc
    Duc Loc 8 months ago in reply to Andrew Beckett
    Thank you Andrew. I'll try this.
