  3. calcVal from CIW returns nil
  • Views 1340
Karam Gh
Karam Gh 8 months ago
Hi all,
I normally run calcVal after selecting "View Results" for a history item in maestro. This works wonderfully.
I would like to move to executing calcVal from CIW without opening the maestro view. I use the following:
calcVal(outputName testName
?lib libName ?cell cellName ?view viewName
?cornerName cornerName ?historyName historyName)
In this case calcVal returns nil. Any suggestions to help evaluate my output without having to manually "View Results" prior to each calcVal?
Guidance is appreciated.
    Andrew Beckett 8 months ago
    I wouldn't expect this to work without an ADE session open, since it's using ADE functionality. If you don't want a graphical session open, I suggest you try using maeOpenSetup() to open a maestro view, and  (probably) maeOpenResults to perform the batch equivalent of view results. If that doesn't work, then please contact customer support (use the Case menu to submit a support case after logging in)
