  3. Scalar Vs. Wave results in OCEAN-XL
  • Subscribers 152
  • Views 1937
shlooky
shlooky 8 months ago
Hi there!
I have been trying for weeks now... please advice Slight smile
I am running a DC sweep simulations with stepped parameter using OCEAN-XL script. Think transistor transfer characteristics...
I also have a CSV file containing data which I want to use as reference for my error calculation. Basically, after every sweep I am trying to calculate error between simulation and CSV data for each parameter value.
My problem is that in Maestro GUI everything works perfectly. By averaging my "error wave" I get scalar number, but when running OCEAN scripts (my own or generated in GUI) I get "wave" result.
How do I get scalar number from "wave" result in this case?
"calcVal" complains about cyclic dependencies, functions "leafValue", "value", "ymax", "mag" all produce wave result after running OCEAN scripts, I guess due to 'sweeps evalType.
There has to be a way how to dig up the scalar number since GUI can do it correctly....
Thanks you guys...
Snippet of my script
ocnxlBeginTest("SETUP")
    simulator('spectre)
    design("myLib" DESIGN "schematic")
    include(strcat(ROOT_DIR "/models.ocn"))
    analysis(
        'dc
        ?dev     "/V_G"
        ?param     "dc"
        ?start     0
        ?stop     "VAR(\"VDD\")"
        ?step     "10m"
    ; Variables
    include(strcat(ROOT_DIR "/07_desVars.ocn"))
    temp(my_Temp)
    desVar("VDD"    my_VDD)
    desVar("frek"   1M)
    desVar("W"      3u)
    desVar("L"      3u)
    desVar("M"      1)
    desVar("NF"     1)
    desVar("VD"     0)
    desVar("VG"     0)
    desVar("VS"     0)
    desVar("VB"     0)
    ocnxlOutputTerminal("/V_D/MINUS" ?save t)
    ocnxlOutputExpr(
        "IS(\"/V_D/MINUS\")"
        ?name         "SIM"
        ?save         t
        ?plot         t
        ?evalType     'point
    ; Down-sample the output for error calculation
    ocnxlOutputExpr(
        "sample(SIM 0 1.2 \"linear\" 25m)"
        ?name         "SAMPLED_SIM"
        ?save         t
        ?plot         t
        ?evalType     'sweeps         ; point, corners, sweeps, maa
    ; Slice-up down-sampled sim data
    ; Output: SAMPLED_SIM_i
    for(i 1 12
        title    = sprintf(nil "SAMPLED_SIM_%d" i)
        expr     = sprintf(nil "leafValue(SAMPLED_SIM \"VD\" %3.2f)" 0.1*i)
        ocnxlOutputExpr(expr ?name title ?save t ?plot t ?evalType 'sweeps)
    ; Import CSV reference data
    ; Output: REFERENCE_i
    file = strcat(CSV_DIR "/reference.csv")
    for(i 1 12
        title    = sprintf(nil "REFERENCE_%d" i)
        expr     = sprintf(nil "getAsciiWave(\"%s\" 1 %d ?xskip 2 ?yskip 2 ?xUnits \"V\" ?yUnits \"A\")" file i+1)
        ocnxlOutputExpr(expr ?name title ?save t ?plot t ?evalType 'point)
    ; Sliced-up error
    ; Output: ERROR_i
    for(i 1 12
        title    = sprintf(nil "ERROR_%d" i)
        expr     = sprintf(nil "((SAMPLED_SIM_%d - REFERENCE_%d) / REFERENCE_%d * 100)" i i i)
    ; AVG error
    ; Output: ERROR_avg_i
    for(i 1 12
        title    = sprintf(nil "ERROR_avg_%d" i)
        expr     = sprintf(nil "average(ERROR_%d)" i)
ocnxlEndTest()
  • Trevor F
    Trevor F 8 months ago
     If you change the various ?evalType to 'point does it work? I'm not too familiar with ocean scripts but according to docs, 'sweeps calculates it across all sweep points, so I'd imagine that is returning a family structure which is why you are getting returned "waves".
  • shlooky
    shlooky 8 months ago in reply to Trevor F
    Hey!
    Thanks for your reply...
    It doesn't work with ?evalType 'point and I need it to be set to 'sweeps.
    I have all reference data available at once, but my simulation data is added incrementally after every sweep.
    I need to pair simulation data with correct reference data based on simulation parameter (VD in my case) for each sweep...
