  3. awvExitWindowFunctionAdd not working as expected
  • Views 1770
Trevor F
Trevor F 8 months ago
Good evening,
I'm trying to attach a callback to both the init and exit actions assosciated with opening/closing windows on ViVA.
To do this I'm using awvInitWindowFunctionAdd and awvExitWindowFunctionAdd.
For testing purposes I'm doing:
procedure(wmAwvWindowHookCB(w_windowID)
print("triggered")
awvInitWindowFunctionAdd('wmAwvWindowHookCB)
awvExitWindowFunctionAdd('wmAwvWindowHookCB)
for some reason, the init works just fine, but the exit doesn't action on plot window close.
I've confirmed they have the same CB:
awvExitWindowFunctionGet()
(wmAwvWindowHookCB)
awvInitWindowFunctionGet()
(wmAwvWindowHookCB)
OUTPUT OF CIW:
_vivaCreateWindow("rectangular")
triggered
window:674
vvCloseWindow("fnxSession1" "win1679" )
nil
_vvSetCurrentWindow("fnxSession1" "win1676" )
t
Unless I'm reading the documentation wrong, I don't understand why the exit callback isn't printing "triggered".
I'm on IC23.1
Thanks, Trevor
    Andrew Beckett 8 months ago
    Trevor,
    I think is something that probably broke many years ago (I think it dates from an older waveform tool, and I suspect it was never properly implemented with ViVA). I just did some experiments looking at various very old versions. The last time that this seems to have worked is in IC5141 but only if you'd switched back to using the older "awd" waveform tool rather than "wavescan" (which was the default then). With "wavescan", the init trigger is called, but not the exit trigger. The same is true in IC614 (which still had the Java graph similar to wavescan). Also in IC615 when the newer ViVA graph was introduced - it's broken there too.
    So, it's been broken for over 20 years (IC5141 was released in 2004) and nobody has ever reported this. If this is important to you, please contact customer support (use the Case menu to submit a support case after logging in) and then a request can be made to R&D to get this fixed. The lack of any reporting of this suggests that nobody is reliant on it though! Typically the init is more important than the exit (e.g. for adding custom menus) so maybe that's why.
    I did find that there is some code (in IC23.1/IC25.1) to call this when Virtuoso exits, but it's only called on any open ViVA windows, and they've already been closed by the time the trigger gets called  - so that doesn't do anything either.
  • Trevor F
    Trevor F 8 months ago in reply to Andrew Beckett
    Ah gotcha that's what I figured.
    My use-case is a plotting tool that lists + eases navigation between plot windows. Thus, I'd like it to be updated on plot window close (exit) and plot window open (init).
    Is there another approach I've missed somewhere else? If you can't think of anything I'll go ahead and make a ticket.
    (Apologies if this posts twice, I got marked for spam the first time around)
    Trevor
    Andrew Beckett 8 months ago in reply to Trevor F
    Trevor,
    Yes, here's a solution. Have two separate functions, and then in the Init trigger use hiRegCloseProc to associate a trigger on that specific window closing:
    procedure(wmAwvWindowInitHookCB(windowId)
      printf("init triggered %L\n" windowId)
      hiRegCloseProc(windowId 'wmAwvWindowExitHookCB)
      t
    procedure(wmAwvWindowExitHookCB(windowId)
      printf("exit triggered %L\n" windowId)
      t
    awvInitWindowFunctionAdd('wmAwvWindowInitHookCB)
    ;awvExitWindowFunctionAdd('wmAwvWindowExitHookCB)
