  3. Virtuoso simulation through ASI command is failing
  • Views 2852
PB202509293935
PB202509293935 8 months ago
Hi ,
I would like to run maestro assembler simulation using CIW command in IC23.1 version, I tried below ASI commands keeping active maestro window.
asiSess = asiGetCurrentSession()
asiRunSimulation(asiSess)
Simulation runs but it shows the error given below. it looks like netlist is not fetching the actual path and skew. before simulation start.
Please note that if I manually click on Run button, netlist fetaches the value and simulation works properly.
Could you please help me with this error.
// Generated for: spectre
// Design Netlist Generated on: Feb 25 05:46:55 2026
// Design library name: ip_vpinlib_ipde
// Design cell name: tb_adcmuxldo_pfmnce
// Design view name: schematic_ext
simulator lang=spectre
include "ade_e.scs"
global 0
parameters vcc v_chop vsupply_mode vref_ext_sel iref_sel0 chop=1 \
contmode=0 vin=450m VXX=900m gnd0=0 fq=100M pwrgateen=0 ldoen=0 \
vref_ext=800m dfx_sel3=0 dfx_sel2=0 dfx_sel1=0 dfx_sel0=0 vref_sel1=0 \
vref_sel0=0 ldo_out0=0 ldo_out1=0 iref_sel1=0 vref_sel2=0 vccdig=0.75 \
vccaon=0.75 vcc1v8=1.25 iload=1m
include "$PROJECT_SCS_FILE" section=tttt
include "netlist"
nbmessage paramtest printif=(1) message="NB JOB ID: $__NB_JOBID"
Error found by spectre during circuit read-in.
ERROR: "input.scs" 14: The file `/p/tech1/n2p/tech-release/XXXX/spectre/include.scs' appears to be in Spectre syntax, but Spectre cannot find the `section tttt' library defined in it. Ensure that the `tttt' section is defined by `section/endsection' block and rerun the simulation.
Best Regards,
Praveen
    Andrew Beckett 8 months ago
    What error? You didn't show an error. I'm not sure what "skew. before simulation start" means.
  • PB202509293935
    PB202509293935 8 months ago in reply to Andrew Beckett
    here is the error message
    Andrew Beckett 8 months ago in reply to PB202509293935
    Can you check in ADE Setup->Model Libraries? I suspect that you have a section name specified there, but maybe in the Corner setup you don't have a section defined for the model files?
    The error suggests that the file is something that should be a straight include without a section specified - does the file have library/section definitions?
    It would be better to go via the mae* functions to run the simulation than use the asi functions (which are more for ADE L). Otherwise it won't take into account some of the Explorer/Assembler related settings.
  • PB202509293935
    Thank you for your help. mae functions helped to resolve the issue.
