  3. AWV Window close callback behavior when closing ViVA Se...
  • Views 2084
AWV Window close callback behavior when closing ViVA Session
Trevor F
Trevor F 8 months ago
Good evening,
I'm attaching an init and close procedure to each individual awvWindow. In doing so, I've found what I expect to be a bug (thoughhopefully I'm just misunderstanding the behavior), and am looking for suggestions on how to work around it.
If I collect the window ids of the individual AWV windows attached to my ViVA session, and I close the viva session (main window containing all the plots)O instead of each plot window, only the first window gets destroyed, and the rest persist.
These are my two test init/exit procedures. I've tested both with and without these and the behavior remains. I'm just leaving this for a potential idea to build off of.
procedure(wmAwvWindowHookCB(w_windowID)
hiRegCloseProc(w_windowID 'wmAwvWindowExitHookCB)
t
procedure(wmAwvWindowExitHookCB(w_windowID)
t
awvInitWindowFunctionAdd('wmAwvWindowHookCB)
Steps to reproduce
wins is the list of AWV windows returned from awvGetWindowList
> wins
(window:257 window:258 window:259 window:260 window:261
window:262 window:263 window:264 window:265
>hiGetWindowList
window:1 .... window:257 window:258 window:259 window:260 window:261 window:262
> Close viva session via top-right X
>wins
(window(invalid):1135496992(destroyed) window:258 window:259 window:260 window:261
>hiGetWindowList
window:1 .... window:258 window:259 window:260 window:261 window:262
What I would expect to happen, is for windows 257 through 265 to be invalid/destroyed. In practice this causes my callback to repeatedly trigger my exit procedures on the first window, 257 and runs a bunch of warnings.
EDIT: The ViVA sesion still closes, I cannot access the awv window anymore, but they're still valid as hiRaiseWindow etc returns t, it just doesn't visually show anything.
I'm on IC23.1
Thanks, Trevor
    Andrew Beckett 8 months ago
    Trevor,
    There are numerous problems with these triggers - clearly it hasn't been implemented properly after the change from AWD back in IC5141. For example:
    1. When I filed the internal CCR 3297118 for the exit trigger not working, I mentioned an observation that when you closed the last window within a session window (using the X on the tab rather than the session window), it auto-adds a new window without calling the init trigger
    2. I just observed that if I use the results browser in ViVA set to "New Window" then double-clicking or Right Mouse->New Window on the signal, that doesn't call the init trigger either
    3. As you say, if you have multiple tabs open and close the containing session window, it only calls the trigger on one of the windows
    You shouldn't really rely on keeping a list of windows and checking whether they are valid or not (but I would expect them to be properly destroyed, I agree). Something is a bit fishy here...
    I'm afraid this is unlikely to get fixed unless you report it to customer support.
  • Trevor F
    Trevor F 8 months ago in reply to Andrew Beckett
    Thanks for the reply! Unfortunately I can't actually contact customer support, as the portal requires 2FA and my company hasn't provided me a key.
    I'd imagine this is a rather larger issue though, as seemingly every user using ViVA is indefinitely growing a list of windows they have no way of clearing (they also exist on the symbol space thus I'd imagine take up space)
    When you say report it to customer support, you mean the Case Creation Form right? Or is there a way to do it by email.
    Trevor
    Andrew Beckett 8 months ago in reply to Trevor F
    Trevor,
    The information you need is the hostid of your license server (look at $CDS_LIC_FILE, ssh onto that machine and run "lmhostid"); whoever looks after your licenses should know this. Failing that, email support@cadence.com and then we may be able to help you create your login and set up the entitlements correctly.
    We don't support submitting support cases by email nowadays - using the support portal is better as it ensures that we capture all the relevant information and often gives suggestions before. submitting the case which might resolve it (not in this case though, I suspect!).
    I don't think the remaining non-destroyed window handle is a big concern - I think it's just a handle that remains (if I try to display the window, it's just empty). This forces them to cleanup:
    foreach(win hiGetWindowList() when(win~>wsId && !member(win awvGetWindowList()) hiCloseWindow(win)))
    Andrew Beckett 8 months ago in reply to Andrew Beckett
    I had a bright idea, so here's a workaround. Note that this doesn't solve the situation where the init trigger is not being called (if the window is opened via the results browser, or because the last tab was closed), but it does ensure that all the exit triggers are called when the overall ViVA window is closed:
    procedure(wmAwvWindowInitHookCB(windowId)
      printf("init triggered %L\n" windowId)
      ; workaround to register a close proc
      hiRegCloseProc(windowId 'wmAwvWindowExitHookCB)
      t
    procedure(wmAwvWindowCleanupAfter()
      ; the variable in the let is a semaphore to prevent re-triggering
      ; this function as each window is closed
      let(((wmWithinAwvWindowCleanupAfter t))
    	hiCloseWindow(win)
      t
    procedure(wmAwvWindowExitHookCB(windowId)
      printf("exit triggered %L\n" windowId)
      ; check the semaphore and schedule the cleanup. Have to use at least
      ; a tenth of a second delay - not hiEnqueueCmd or 0 for the timer - because
      ; the awvGetWindowList() is not emptied immediately.
      unless(boundp('wmWithinAwvWindowCleanupAfter) && wmWithinAwvWindowCleanupAfter
        hiRegTimer("wmAwvWindowCleanupAfter()" 1)
      t
    awvInitWindowFunctionAdd('wmAwvWindowInitHookCB)
    I did file an internal CCR for the situation that the windows are not being closed properly - CCR 3302185.
