  3. Change instance name prefixes automatically
  • Views 1339
MF202512032436
MF202512032436 7 months ago
Hi all,
I would like to change all instance name prefixes for a group of cells placed in a schematic:
Example:
All cells with the cell-name starting with "nch" (so n-MOS devices) should have the instance name prefix "N". The old prefix M or MN should be removed.
Thanks for your help
Martin
    Andrew Beckett 7 months ago
    Martin,
    This code (that I threw together, so not especially polished) can do this easily enough:
    procedure(CCFrenameInsts(@key (cv geGetEditCellView()) cellPattern fromPattern replacement "gttt")
      let((
        (cellPat pcreCompile(cellPattern))
        (fromPat pcreCompile(fromPattern))
        instName changed
        foreach(inst cv~>instances
          when(pcreExecute(cellPat inst~>cellName)
            instName=pcreReplace(fromPat inst~>name replacement 1)
            unless(inst~>name==instName
              inst~>name=instName
              changed=t
        changed
    You'd use it like this:
    CCFrenameInsts(?cellPattern "^nch" ?fromPattern "^MN?" ?replacement "N")
    The ?cellPattern is a regular expression for the matching cell names (i.e. begins with nch); the ?fromPattern is a regular expression for matching instance names (begins with M, followed by 0 or 1 N) and the replacement is what you want that part of the instance name to be replaced with.
