  3. how to merge points??
  • Views 941
Noobnoob
Noobnoob 7 months ago
Hello guys
I had to merge points
But, i didn't understand dbPointArrayOr() Function Well...
a = ( (0.0 0.0) (0.0 5.0) (5.0 5.0) (5.0 0.0) )
b = (0.0 0.0)
c = dbPointArrayOr( geGetWindowCellView() list(a) list(list(b)) )
What did i do wrong??
please tell me about dbPointArrayOr()...
    Andrew Beckett 7 months ago
    dbPointArrayOr will perform a Boolean or of two lists of polygons, described using point lists. Your second point list is a list of a single point which is a zero-area polygon and hence there is nothing to “or”. This is unlikely to be doing what you want here…
    What do you mean by “merging points”? What are some example inputs and expected outputs from such an operation?
