  3. How to use dbOpenCellViewByType() to create a Spectre view...
  • Views 1898
How to use dbOpenCellViewByType() to create a Spectre view ?
Umbrajo
Umbrajo 6 months ago
I am trying to automate the creation of components with Spectre netlists using SKILL (v. ICADVM20.1-64b.).
When I want to use the function dbOpenCellViewByType(libName cellName "Spectre" "Spectre" "w"), I get " *WARNING* (DB-270208): dbOpenCellViewByType: unrecognized database viewType 'Spectre' " in the CIW and no view is created.
I tried with the following formatting for the word "spectre": "Spectre" and "spectre". I get the same issue. I looked for information to overcome this issue in "SKILL Language User Guide", "SKILL Language Reference" and especially in "Virtuoso Design Environment SKILL Reference" but no detail could help me.
I am confused because Spectre views are possible to create with the Library Manager (when using the graphical interface).
So 2 questions:
1. Where should I look in order to view which viewTypes are recognized by SKILL ?
2. If you think I am trying to create Spectre views with SKILL the wrong way, could you suggest a new way ?
Thanks for reading and for your help.
Sincerely,
Umbrajo.
    Andrew Beckett 6 months ago +1
    Umbrajo, The db APIs are for creating OpenAccess cellViews (e.g. schematic, symbol, layout) and not for textual views such as the spectre view. Now that's not entirely true - there is an accompanying…
    Umbrajo,
    The db APIs are for creating OpenAccess cellViews (e.g. schematic, symbol, layout) and not for textual views such as the spectre view. Now that's not entirely true - there is an accompanying "shadow" database alongside the text view information which records information such as the I/O terminals to aid the netlister, and that is in OA, but that's not going to do what you want in this case which is to create the cellVIew with the appropriate master.tag file to indicate that it's a spectre textual view.
    Now, there is this SKILL code I wrote many years ago: How to create a text cellview using SKILL but this would only do part of the job for you (it wouldn't create the OA part needed for netlisting). You could do that with the function in this article: SKILL API for extracting DSPF and Spectre Text Editor views to create shadow database
    However, as also mentioned as a reference within that second article, it might just be simplest to use the command-line cdsTextTo5x utility with the -lang spectre argument to do all the work for you.
  • Umbrajo
    Umbrajo 6 months ago in reply to Andrew Beckett
    Andrew,
    Thank you for your answer and for your help.
    I confirm that the command cdsTextTo5x works correctly.
    Umbrajo.
