  3. skill code for maestro
  • Subscribers 150
  • Views 1904
AS202509094448
AS202509094448 6 months ago
I want to use skill code in non gui method to save maestro history. Like manually it is in toolbar options-> save->hisotry
envSetVal("adexl.simulation" "saveLastNHistoryEntries" 'int 200)
Above command is working in CIW but it is limited to this icfb session. And gets reset at new icfb launch.
I want to use it for particular maestro in all icfb session. If I will edit cds.env file, it will set for all maestros.
    Andrew Beckett 6 months ago +1
    The setting is not per-maestro view. If you set the number of histories to save from Options->Save, all it does is set the environment variable you have mentioned above. So the SKILL you already have is…
  • AS202509094448
    AS202509094448 6 months ago in reply to Andrew Beckett +1
    Thanks Andrew. But why can't we use skill for all the manual setting? Is there any plan in future to do something like this? Like manually we can set it using options->save for separate maestro. But there…
    The setting is not per-maestro view. If you set the number of histories to save from Options->Save, all it does is set the environment variable you have mentioned above. So the SKILL you already have is the only way to do this - you cannot have one setting for one maestro view and a different setting for another.
  • AS202509094448
    Thanks Andrew. But why can't we use skill for all the manual setting? Is there any plan in future to do something like this? Like manually we can set it using options->save for separate maestro. But there is no function for maestro right now to access this option/variable.
    Andrew Beckett 6 months ago in reply to AS202509094448
    You can use SKILL for doing this setting. It's the envSetVal() call you mentioned before.
    To illustrate this - if you have two maestro sessions open, and then do Options->Save in one of them and change the number of history points saved and OK the form. Then in the second maestro session bring up Options->Save and you'll see that the number of history points to be saved is as it was in the other session. In other words, this is not a session-specific setting. It's a global setting, and is just setting the environment variable from a common form.
    Unless we changed this to be a per-maestro-session setting (which there is no plan to do), there would be no point having a different API to set it because it just sets the environment variable.
