  3. equivalent skill function to the unix dirname command
  • Subscribers 150
  • Views 1097
kkdesbois
kkdesbois 6 months ago
Is there an API that returns the directory path of a full path, like unix dirname command
I currently use this syntax
(buildString (reverse (cdr (reverse (parseString (simplifyFilename fileName) "/")))) "/")
Is there a more elegant way to do the same?
Laurent.
  • Aurel B
    Aurel B 6 months ago
    Hi Laurent,
    I generally use :
    (simplifyFilename (strcat path "/.."))
    Surprisingly it also works with file paths.
    Aurélien
    Andrew Beckett 6 months ago in reply to Aurel B
    I've always tended to use regular expressions. Something like:
    baseNamePat=pcreCompile("[^/]*$") ; could add a "/" at the beginning if you don't want a trailing / in the dirName
    dirName=pcreReplace(baseNamePat originalPath "" 1)
