  3. Re: Skill or environment setting for Job Policy Setup
  • Views 872
SL20260319720
SL20260319720 6 months ago
Is there skill commands or environment variables that will allow one to set the values for "parallel environment" and "Parallel Num. Process" within the Job Policy Setup->Simulation for Explorer?
Su Lim
    Andrew Beckett 6 months ago
    Look at the documentation for axlSetJobPolicyProperty. You can retrieve the settings in a job policy (it gives an example) and then see the names of the job policy property you'd want to set via SKILL.
    Alternatively, define a job policy interactively and then set that to be your default.
