  3. how to make the variables and utilize the coordinates.
  • Replies 7
  • Views 2449
Noobnoob
Noobnoob 6 months ago
Hello, i'm sorry for my english skill.
As a title, i wonder how to make variables and count those.
I'm making Layout Skill that count Channel of MOS by using skill language.
For example,
if two MOS that have w = 5um & l = 5um and two MOS that have w = 3um & l = 5um are placed in top level Layout Cellview.
I want to show that number of each MOS that include channel size in CIW.
CIW :
width = 5um & length = 5um, multi = 2ea
width = 3um & length = 5um, multi = 2ea
Presently, i got coordinate of each channel in top level.
But, i have trouble with utilzing coordinates...
How can i make variables by size and count those....?
below, i made a script by using skill language and wonder how to utilize coordinates.
    Andrew Beckett 6 months ago in reply to Noobnoob +1
    Add these two functions: ;------------------------------------------------------------------------ ; Convert a list of pointLists to a list of W and L ; values; W is the height, L is the length. ;--…
  • Noobnoob
    wcv = geGetWindowCellView()
    poly_overlaps = dbGetTrueOverlaps(wcv wcv~>bBox list("POLY" "drawing") 32 t);you got db id of all poly layer.
    poly_point = foreach(mapcar poly_overlap poly_overlaps
    TransBBoxToPoint(dbTransformBBox(ExtractLayerDB(poly_overlap)~>bBox dbGetInstTransform(poly_overlap)))
  • Noobnoob
    diff_overlaps = dbGetTrueOverlaps(wcv wcv~>bBox list("DIFF" "drawing") 32 t);you got db id of all diff layer.
    diff_point = foreach(mapcar diff_overlap diff_overlaps
    case( ExtractLayerDB(diff_overlap)~>objType
    ( "rect" TransBBoxToPoint(dbTransformBBox(ExtractLayerDB(diff_overlap)~>bBox dbGetInstTransform(diff_overlap))))
    ( "path" dbTransformPointList(dbConvertPathToPolygon(ExtractLayerDB(diff_overlap))~>points dbGetInstTransform(diff_overlap)))
    ( "polygon" dbTransformPointList(ExtractLayerDB(diff_overlap)~>points dbGetInstTransform(diff_overlap)))
    pimp_overlaps = dbGetTrueOverlaps(wcv wcv~>bBox list("PSD" "drawing") 32 t)
    pimp_point = foreach(mapcar pimp_overlap pimp_overlaps
    case( ExtractLayerDB(pimp_overlap)~>objType
    ( "rect" TransBBoxToPoint(dbTransformBBox(ExtractLayerDB(pimp_overlap)~>bBox dbGetInstTransform(pimp_overlap))))
    ( "path" dbTransformPointList(dbConvertPathToPolygon(ExtractLayerDB(pimp_overlap))~>points dbGetInstTransform(pimp_overlap)))
    ( "polygon" dbTransformPointList(ExtractLayerDB(pimp_overlap)~>points dbGetInstTransform(pimp_overlap)))
    nimp_overlaps = dbGetTrueOverlaps(wcv wcv~>bBox list("NSD" "drawing") 32 t)
    nimp_point = foreach(mapcar nimp_overlap nimp_overlaps
    case( ExtractLayerDB(nimp_overlap)~>objType
    ( "rect" TransBBoxToPoint(dbTransformBBox(ExtractLayerDB(nimp_overlap)~>bBox dbGetInstTransform(nimp_overlap))))
    ( "path" dbTransformPointList(dbConvertPathToPolygon(ExtractLayerDB(nimp_overlap))~>points dbGetInstTransform(nimp_overlap)))
    channel_point = dbPointArrayAnd(wcv poly_point diff_point)
    p_channel_point = dbPointArrayAnd(wcv channel_point pimp_point)
    n_channel_point = dbPointArrayAnd(wcv channel_point nimp_point)
  • Noobnoob
    procedure( ExtractLayerDB(value)
    prog( (run)
    run = 1
    while(run == 1
    if(listp(value) == t then
    value = cadr(value)
    else
    value
    run = 0
    );if
    );while
    return(value)
    );prog
    );procedureS
    procedure( TransBBoxToPoint(bBox)
    prog( (x1y1 x2y2 x1y2 x2y1)
    x1y1 = nthelem(1 bBox)
    x2y2 = nthelem(2 bBox)
    x1 = xCoord(x1y1)
    y1 = yCoord(x1y1)
    x2 = xCoord(x2y2)
    y2 = yCoord(x2y2)
    x1y2 = (x1:y2)
    x2y1 = (x2:y1)
    point = list(x1y1 x1y2 x2y2 x2y1)
    return(point)
    );prog
    );procedure
    procedure( TransPointToBBox(point)
    prog( (x1y1 x2y2 result)
    x1y1 = nthelem(1 point)
    x2y2 = nthelem(3 point)
    result = list(x1y1 x2y2)
    return(result)
    );prog
    );procedure
    OK, your code just finds the gate shapes for N or P devices, but I suspect you want to find the actual PCell instances instead? You could process the polygons to try to compute the width and length (assuming they are rectangular, but you've lost the orientation information). Wouldn't traversing the hierarchy to find the instances of particular cells and then looking at their parameters be easier?
    I guess it depends on what you're aiming to do with the results.
  • Noobnoob
    Noobnoob 6 months ago in reply to Andrew Beckett
    Thank you for reply!
    I have difficulty in understanding your reply because my English skills are not good and i'm junior for my layout job...(2 years)
    But, I am tring to understanding your reply by using Google Translater...!
    as you think, i just finded the coordinates of gate shapes for N or P devices.
    But, I didn't use PCell.
    Because my company dont use pcell to shink chip size.
    I made a De_cap Cell myself and placed it in layout cell view.
    So, I just want to decide width and length by using x coordinates and y coordinates.
    (width = gap of y coordinates, length = gap of x coordinates)
    Of course, i will continue to develop my skill code with orientation !!
    But it's too hard to use orientation information to me as junior.
    Honestly, I didnt understand your reply " Wouldn't traversing the hierarchy to find the instances of particular cells"... sorry...
    you say, do i need to use "dbGetTrueOverlaps"??
    As a result, as junior, first step, i want to use coordinates of gate to count De_caps by size !!!
    thank you for reading my post!
    could you help me develop skill code to count de_caps by using coordinates??
    - Noobnoob-
    procedure( CCFpointListToWL(cv pointList)
      let((llx lly urx ury (DBUPerUU cv~>DBUPerUU))
        foreach(point pointList
          destructuringBind((x y) point
            llx=if(llx then min(llx x) else x)
            lly=if(lly then min(lly y) else y)
            urx=if(urx then max(urx x) else x)
            ury=if(ury then max(ury y) else y)
        ; Convert to database units, round and back to microns.
        ; This is because simply subtracting floating point
        ; numbers will give small floating point errors leading
        ; to tiny differences in otherwise identical dimensions.
        ; Converting to integer units will ensure uniformity of
        ; the widths and lengths
        list(
          round((ury-lly)*DBUPerUU)/DBUPerUU
          round((urx-llx)*DBUPerUU)/DBUPerUU
    ; Count each combination of w and l and then report
    procedure( CCFcountAndReportWL(wlList)
      let(((wlTable makeTable('wlTable 0)))
        foreach(wl wlList
          wlTable[wl]=wlTable[wl]+1
        foreach(wl wlTable
          destructuringBind((w l) wl
            printf("  width = %gum & length = %gum, multi = %d\n"
              w l wlTable[wl]
        t
    Then use them as follows (at the end of your existing code):
    p_channel_wl=foreach(mapcar pointList p_channel_point CCFpointListToWL(wcv pointList))
    n_channel_wl=foreach(mapcar pointList n_channel_point CCFpointListToWL(wcv pointList))
    printf("P Channel\n")
    CCFcountAndReportWL(p_channel_wl)
    printf("N Channel\n")
    CCFcountAndReportWL(n_channel_wl)
    You'll then get output in the CIW something like this:
    P Channel
      width = 20um & length = 0.28um, multi = 44
      width = 1.2um & length = 0.28um, multi = 1
      width = 20um & length = 0.5um, multi = 48
      width = 6.755um & length = 7.2um, multi = 4
      width = 2.8um & length = 0.28um, multi = 1
    N Channel
      width = 1.12um & length = 0.28um, multi = 1
      width = 1.2um & length = 0.28um, multi = 4
      width = 10um & length = 1um, multi = 14
      width = 3um & length = 0.28um, multi = 12
  • Noobnoob
    Thank you! Andrew!!
    I got a result that i want!!!
    I'll try to analyze your code!!
    -noob-
